There doens’t seems to be a USB stick mounted. At least it’s not sown on our df output. Can you check
You have a 4GB gravity.db. And this 3 times. One original file and 2 backup files.
My recommendation would be to use just one backup and not 2 backup generations. Or to check where the backup usb stick is gone
Klola
22
Actually, I was convinced all along that my backups were stored on the USB stick. At least that’s what I always thought.
root@DietPi:~# lsblk -o name,fstype,label,size,ro,type,mountpoint,partuuid,uuid
NAME FSTYPE LABEL SIZE RO TYPE MOUNTPOINT PARTUUID UUID
sda 14,5G 0 disk
└─sda1
xfs 14,5G 0 part /mnt/usbst 7cbab241-01 05c23ede-c892-4e5f-839f-a3855f73eabd
mmcblk0
│ 14,7G 0 disk
├─mmcblk0p1
│ vfat boot 256M 0 part /boot 907af7d0-01 4AD7-B4D5
└─mmcblk0p2
ext4 rootfs
14,5G 0 part / 907af7d0-02 2887d26c-6ae7-449d-9701-c5a4018755b0
Yes it is not mounted to /mnt/usbstick/
Best is to mount the stick to a temp location, move content of /mnt/usbstick/ to the stick and re-mount it afterwards to correct place
Klola
24
Thanks, I’ll probably just plug in another USB stick, mount it, create a backup.
Remove the old USB stick (delete backups) and then create a backup there as well. I trust myself to delete incorrect backups on the SD card.
