Damn, okay. Thanks for pointing that out. I should have read more carefully.
DDNS having the correct external IP address (mxtoolbox says yes) ︎
port forwarding done ︎
correct local device IP (static) ︎
client having the correct settings (probably) ︎
pass pivpn debug (ok) ︎
I managed to resolve the situation. Simply rebooted the router, the iPhone, and the RaspberryPi. I guess there’s no way to run a sh script on an iPad or iPhone though.
It’s either the client side (i.e. iDevice) or some obscure configuration that makes PiVPN/Wireguard unstable for me. It mostly works, however from time to time it simply stops functionning. It’s fickle!
The client device mostly shows up as currently connected, when I then run pivpn -c
, but I can’t connect to my local network.
