I get that. But what about radarr then. If I run the chow command for sonarr and do it again for radarr, wouldn’t it switch the user then?
Radarr should be able to access files and folders via group permissions.
Ok, did that, still nothing, here’s what came out.
root@DietPi:~# chown -R sonarr:dietpi /mnt/c1paScorpioDataSeries/
root@DietPi:~# chmod -R 775 /mnt/c1paScorpioDataSeries/
root@DietPi:~# ls -la /mnt/c1paScorpioDataSeries/Alias/
total 8
drwxr-xr-x 2 root root 0 Sep 2 07:54 .
drwxr-xr-x 2 root root 0 Sep 2 07:33 ..
drwxr-xr-x 2 root root 0 Aug 24 02:12 'ALIAS (2001-2006) - Complete TV Series, Season 1,2,3,4,5 S01-S05 - 720p AMZN Web-DL x264'
-rwxr-xr-x 1 root root 5676 Aug 25 22:04 tvshow.nfo
also tried the first 2 commands with sudo in front, same thing
What filesystem do you use for the mount in question?
Synology Hybrid RAID (SHR), has worked before.
Can you repeat the commands with verbos option:
chown -Rv sonarr:dietpi /mnt/c1paScorpioDataSeries/
chmod -Rv 775 /mnt/c1paScorpioDataSeries/
Let’s check following in addition
df -h
udev 3.9G 0 3.9G 0% /dev
tmpfs 795M 8.7M 786M 2% /run
/dev/sda1 504G 3.5G 475G 1% /
tmpfs 3.9G 4.0K 3.9G 1% /dev/shm
tmpfs 3.7G 0 3.7G 0% /tmp
tmpfs 50M 3.5M 47M 7% /var/log
//192.168.1.129/series 11T 6.2T 4.3T 59% /mnt/c1paScorpioDataSeries
this is the output of df -h
gives a long list that it changed te user with the chown verbos commands, but when I try to create the file as sonarr user (see above comment from Joulinar), it still gives the deny and when I look, no user is changed
can you share
cat /etc/fstab
# NETWORK
# TMPFS
tmpfs /tmp tmpfs size=3754M,noatime,lazytime,nodev,nosuid,mode=1777
tmpfs /var/log tmpfs size=50M,noatime,lazytime,nodev,nosuid
# MISC: ecryptfs, vboxsf, glusterfs, mergerfs, bind, Btrfs subvolume
# SWAP SPACE
# PHYSICAL DRIVES
UUID=01c5a930-e104-43a6-9049-51b73c030b64 / ext4 noatime,lazytime,rw 0 1
There is nothing about the network share in. How do you mount it?
Like this:
mount -o username=user_name //192.168.1.129/series /mnt/c1paScorpioDataSeries
Can you try mounting using DietPi drive manager. There should be no need to specify a user
Yes that did it. Very odd, cause I tried this before and it did not work then. Maybe with all that we tried now, on combination with doing this again solved it. Anyway thanks for all the help. Also learned a bit. Guess that’s also a positive thing.
