Odroid C1+ lag issue
Hi.
I updated to the newest.
I can add that i changed usb drive to 2TB new external drive (with own powersuplly) , updated dietpi , and this problem started.
Is this could be HHD problem connected ? its Seagate Expansion 2TB
Generally it got crazy…:
Transmission is very slow (it reach 70% of speed - like it was limited) then it drop to 0, then speed up and again drop it to 0…
SSH terminal lag when i type in it.
Loading take much longer, after reeboot.
System freeze often.
The CPU is max even when idle = strange…and hot
proftp.transmission.kodi - installed
Hi Marg,
Lets check whats using up the CPU time, can you please run this command, then take a picture:
htop
Also, can you please send us a bug report so we can check system configuration and settings:
https://dietpi.com/forum/t/send-dietpi-a-bug-report/421/1
Hi mate.
Transmission is overtaking CPU.
After few reboots - everything working fine now (!?)
strange…
I think i need upgrade to C2.
For now we can delete topic.
greets
