tmp is full again, restart of lms has no succes,
but i found that nextcloud is logging every second, i was not aware of this.
I changed the loglevel in var/www/nextcloud/config/config.php
from 0 to 2.
Can i see in tmp if nextcloud has a PrivateTmp and could be the cause for full /tmp directory?
I answer myself, i found
Doctrine\DBAL\Exception\DriverException: An exception occurred while executing a query: SQLSTATE[HY000]: General error: 1021 Disk full (/tmp/#sql-temptable-3aa-11e5-ca.MAI); waiting for someone to free some space... (errno: 28 "No space left on device")
in the log were mostly keepassweb, recognize, music, workflowocr, i disabled these apps.
I reboot and keep an eye on nextcloud.
root@DietPi4 [21:02:58]/tmp # systemctl restart logitechmediaserver
root@DietPi4 [21:03:03]/tmp # df -h
Dateisystem Größe Benutzt Verf. Verw% Eingehängt auf
/dev/root 235G 113G 112G 51% /
devtmpfs 1,9G 0 1,9G 0% /dev
tmpfs 1,9G 1,7M 1,9G 1% /dev/shm
tmpfs 764M 78M 687M 11% /run
tmpfs 5,0M 4,0K 5,0M 1% /run/lock
tmpfs 1,9G 1,9G 0 100% /tmp
tmpfs 50M 104K 50M 1% /var/log
/dev/mmcblk0p1 253M 52M 201M 21% /boot
tmpfs 382M 8,0K 382M 1% /run/user/999
/dev/sda1 113G 62G 51G 55% /mnt/128
/dev/sdb1 229G 160G 69G 70% /mnt/256
tmpfs 382M 8,0K 382M 1% /run/user/0
root@DietPi4 [21:03:06]/tmp # G_TREESIZE /tmp
0,0 bytes /tmp/.XIM-unix
0,0 bytes /tmp/.X11-unix
0,0 bytes /tmp/.Test-unix
0,0 bytes /tmp/systemd-private-7437effbbf6943d58b62f89f700b21b3-systemd-logind.service-pKtWvi
0,0 bytes /tmp/systemd-private-7437effbbf6943d58b62f89f700b21b3-redis-server.service-GRG9Ai
0,0 bytes /tmp/systemd-private-7437effbbf6943d58b62f89f700b21b3-logitechmediaserver.service-oVWvSg
0,0 bytes /tmp/systemd-private-7437effbbf6943d58b62f89f700b21b3-coturn.service-S9OB5g
0,0 bytes /tmp/.ICE-unix
0,0 bytes /tmp/.font-unix
0,0 bytes /tmp
