- DietPi version
G_DIETPI_VERSION_CORE=8
G_DIETPI_VERSION_SUB=11
G_DIETPI_VERSION_RC=2
G_LIVE_PATCH_STATUS[0]=‘not applicable’ - Distro version
bullseye - Kernel version
Linux DietPi 5.15.76-rockchip64 #22.08.8 SMP PREEMPT Sun Oct 30 10:57:32 CET 2022 aarch64 GNU/Linux - SBC model
NanoPi NEO4 (aarch64) - SD card used
SanDisk ultra 32GB
I just installed a fresh diepi on my NanoPi NEO4. After basic configuration I installed kodi via dietpi-software.
Since I like to use iptvsimple i did:
apt-get update
apt-get install kodi-pvr-iptvsimple
Everytime I start kodi with startkodi I get this messages:
failed to open zone.tab
libva info: VA-API version 1.10.0
libva error: vaGetDriverNameByIndex() failed with unknown libva error, driver_name = (null)
After configuring iptvsimple I switched to TV, I got some crackling noise on my monitor (connected via hdmi). The tv-stream is running, but all 6 cores of my NEO4 are at 100% CPU now.
I tried using LibreElec just to compare. With LiberElec CPU load is about 40% only and sound works fine. But with LibreElec WiFi did not work
How to solve the errors showed above?
How to reduce CPU load?
How to get sound work?
Henning
