No audio, only card 0 appears
não consigo fazer sair audio, nao sei mais o q fazer?
help pls
Please post in English.
I can’t make audio come out, I don’t know what else to do?
Can you share some more system details
Required
  • Kernel version | uname -a
update - via hdmi cable the sound comes out, but the jack does not and I need it
dietpi@DietPi:~$ aplay -l
card 0: sun9ihdmi [sun9i-hdmi], device 0: SUN9I-HDMI PCM i2s-hifi-0 [SUN9I-HDMI PCM i2s-hifi-0]
  Subdevices: 0/1
  Subdevice #0: subdevice #0
dietpi@DietPi:~$ amixer contents
numid=4,iface=MIXER,name='Master Playback Switch'
  ; type=BOOLEAN,access=rw------,values=1
  : values=on
numid=3,iface=MIXER,name='Master Playback Volume'
  ; type=INTEGER,access=rw------,values=2,min=0,max=65536,step=1
  : values=66243,66243
numid=2,iface=MIXER,name='Capture Switch'
  : values=on
numid=1,iface=MIXER,name='Capture Volume'
  : values=65536,65536
dietpi@DietPi:~$
the card that would be for plug does not appear, does anyone have an idea?
@MichaIng I noticed that you are an expert in sound, can you help me
Did you already try to change the output via dietpi-config?
yes, unsuccessful
The overlay for analogue audio needs to be enabled. See here: DietPi-Config | Add Allwinner H3 analogue 3.5mm onboard audio · Issue #6093 · MichaIng/DietPi · GitHub
I’ll work now on implementing this into dietpi-config. Not too difficult.
EDIT: Done: DietPi-Config | Add Allwinner H3 analogue 3.5mm onboard audio by MichaIng · Pull Request #6447 · MichaIng/DietPi · GitHub
