Need help with wireguard
Alright, one last thing, the myddns endpoint is IPv4 or IPv6?
It’s on the dietpi ddclient is running and it’s an a ipv6 address
Try this and if it works we can make it permanent.
echo '10 isp' >> /etc/iproute2/rt_tables
ip -6 route add to default via "$(ip -6 route list match ::/0 | cut -f3 -d ' ')" dev eth1 table isp
ip -6 rule add iif lo sport 51820 to default lookup isp prio 15
amazing :slight_smile: perfect runs smooth :slight_smile:
But I can’t connect to the internal network
even if I have
AllowedIPs = 192.168.178.0/24
in my client conf
why not using 0.0.0.0/0 within your client configuration?
Still not working
I only can connect to 192.168.178.43 which is my dietpi’s ip and the Internet but mother local address
without yor ip rule it’s running but than if i connect to openvpn wireguard is not connecting
You need to change the allowed IPs on the client device WG configuration.
Then the other lan hosts are using the ISP router as gateway, so you need to apply also masquerade on eth0 egress traffic.
If there is some killswitch from the vpn client, you need to bypass that too.
Okay,
this is my current client conf file
[Interface]
Address = 10.0.0.2/32
PrivateKey = [privatekey]
# Comment the following to preserve the clients default DNS server, or force a desired one.
DNS = 192.168.178.43
# Kill switch: Uncomment the following, if the client should stop any network traffic, when disconnected from the VPN server
# NB: This requires "iptables" to be installed, thus will not work on most mobile phones.
#PostUp = iptables -I OUTPUT ! -o %i -m mark ! --mark $(wg show %i fwmark) -m addrtype ! --dst-type LOCAL -j REJECT; ip6tables -I OUTPUT ! -o %i -m mark ! --mark $(wg show %i fwmark) -m addrtype ! --dst-type LOCAL -j REJECT
#PreDown = iptables -D OUTPUT ! -o %i -m mark ! --mark $(wg show %i fwmark) -m addrtype ! --dst-type LOCAL -j REJECT; ip6tables -D OUTPUT ! -o %i -m mark ! --mark $(wg show %i fwmark) -m addrtype ! --dst-type LOCAL -j REJECT
[Peer]
PublicKey = [publickey]
Endpoint = xx.io:51820
# Uncomment the following, if you're behind a NAT and want the connection to be kept alive.
#PersistentKeepalive = 25
What do I need to change now?
Not sure if related but your DNS is a PiHole and located on same system as WireGuard Server?
Btw: the client file needs to be uploaded to your client each time you change something or your do changes on the client app directly. Just updating client file on server will not have any effect.
yes it’s a pihole located on the same dietpi than my wireguard server
And I edit the conf file on my mobile phone directly
How do I do this
PostUp = iptables -t nat -I POSTROUTING -o eth0 -j MASQUERADE
just out of interest, you see DNS request arriving from VPN client within PiHole? Sometimes it is needed to allow PiHole to accept request from all interfaces.
yes i see and they get also blocked…tested yesterday evening…i am not at home so need to test again
So with
and
everything seems to run as expected.
How can I do this permanent now?
The entry in rt_tables is permanent. Add the others in a dietpi-autostart script.
dietpi-config #9 AutoStart Options → #14 Custom script (background, no autologin)
Is it also possible to route all wlan0 data to the tun1?
I use this right now
sudo /usr/sbin/ip route add default via 10.8.110.19 dev tun1 table 200
sudo /usr/sbin/ip rule add from 192.168.42.0/24 table 200
sudo /usr/sbin/ip route flush cache
Or is there a better way?
I think it is quite alright.
Also possible to write this ip independent?
I am not sure I understand your question.
there you can see it’s specific for the IP 10.8.110.19 how can I change it to all IPs so I don’t need to care about this IP?
If it is a point to point tunnel, then try to omit the via IP, it may as well work without it.
