Need help with flags to compile a file
I try to compile a file with make/g++. But the file ‘Makefile.arm’ has to be tweaked for Raspberry 4 with DietPi 64bit.
Please can someone tell me how to change the flags, that the compiling process will work without a fault? I don’t find any information how to to this.
Thank you!
Flags to be changed:
CXXFLAGS=-O3 $(PROFILING) -mfpu=crypto-neon-fp-armv8 -mfloat-abi=hard -ftree-vectorize -ffast-math \
	      -std=c++0x -Wall \
	      -Wno-unused-function  -Wno-unused-variable -Wno-unused-but-set-variable \
	      -Wno-write-strings
Error-Message:
sudo make -f Makefile.arm
g++ -O3  -mfpu=crypto-neon-fp-armv8 -mfloat-abi=hard -ftree-vectorize -ffast-math -std=c++0x -Wall -Wno-unused-function                                               -Wno-unused-variable -Wno-unused-but-set-variable -Wno-write-strings    -c main.cpp
g++: error: unrecognized command-line option ‘-mfpu=crypto-neon-fp-armv8’
g++: error: unrecognized command-line option ‘-mfloat-abi=hard’
The whole ‘Makefile.arm’:
PACKAGES= librtlsdr
CXX=g++
PROFILING=
DEFINES=
PKG_INCLUDES= $(shell pkg-config --cflags $(PACKAGES))
PKG_LIBS= $(shell pkg-config --libs $(PACKAGES))
	      -std=c++0x -Wall \
	      -Wno-write-strings
INCLUDES= $(PKG_INCLUDES)
LIBS=-lm $(PKG_LIBS) -lpthread
LDFLAGS=$(PROFILING) -rdynamic
CFILES=main.cpp engine.cpp  dsp_stuff.cpp fm_demod.cpp decoder.cpp crc8.cpp \
	tfa1.cpp tfa2.cpp utils.cpp sdr.cpp whb.cpp crc32.cpp
OBJS = $(CFILES:.cpp=.o)
all: tfrec
tfrec: $(OBJS)
	 $(CXX) $(LDFLAGS) -o $@ $(OBJS) $(LIBS)
.cpp.o:
	$(CXX) $(CXXFLAGS) $(DEFINES) $(INCLUDES) -c $<
ifneq ($(MAKECMDGOALS),clean)
include .depend
endif
.depend: Makefile
	touch .depend
	makedepend $(DEF) $(INCL)  $(CFLAGS) $(CFILES) -f .depend >/dev/null 2>&1 || /bin/true
clean :
	$(RM) $(OBJS) *~
	$(RM) tfrec
	$(RM) .depend
