Need Help Locating Stacks Directory (DietPi/Portainer)
Hi all,
I’m using the Dockge Docker container (Dockge) and struggling to find the default stacks directory for DietPi/Portainer.
Any pointers? Much appreciated!
Thanks,
What exactly you are looking for? We don’t have a default directory where you can store compose.yaml files
According to their GitHub the default directory is /opt/stacks
https://github.com/louislam/dockge?tab=readme-ov-file#basic
I’m looking for the folder where Portainer stores the docker compose files
Basically, when you create a stack, i would like to know where its stored
Default should be /opt/stacks, but it isn’t …
Something you need to ask Portainer? I’m not sure if Portainer is storing the information on files. Probably within a database? Or within the Docker volume?
At least Docker data is located at /mnt/dietpi_userdata/docker-data
I made a quick test installation and you probably are talkin about /mnt/dietpi_userdata/docker-data/volumes/portainer_data/_data/compose
Thanks for your prompt help!
That’s what I was looking for :slight_smile:
