Hi
I am trying to start dietpi DietPi_NanoPiM3-ARMv8-Bullseye.img on my nanopi M3 But somehow the dialog is starting and with the lines and it reboots on and on again and it doesn’t go to the configuration forward. whats wrong?
The M3 is very sensitive towards power supply resp. USB cables.
Tra to use a better cable and/or a better power converter.
When I use “thin” USB cables, I also have these reboots.
thanks
With cabels i was allready checking everything. maybe should I try other power converter. but I have a good one from huawei 5V 2A converter. has anyone any tip for a better one?
I needed to try a couple of them until I found a feasible one.
