My external HDD replacement plan -- advice needed
I guess you mixing thinks.
That’s my specialty!
I’ve confirmed now that /mnt/media/ is now pointing to the new drive. After modifying fstab, I restarted all my services, and sab immediately told me it couldn’t write to /media. I assume this is because of that mount -o remount,ro /mnt/media command I ran before running rsync. But a restart fixed everything.
yes, a reboot was necessary to appley the new mount setting. Just changing them on fstab did not perform any re-mount :wink:
Do I have to turn swap back on manually after issuing the swapoff -a command? I notice, looking at RPi-Monitor, that my swapfile is only just under 13MB.
dietpi@DietPi:~$ cat /proc/meminfo | grep Swap
SwapCached:         2184 kB
SwapTotal:       1115132 kB
SwapFree:        1102076 kB
just run following. It will appley all necessary settings automatically
/boot/dietpi/func/dietpi-set_swapfile
Btw, to install rsync:
apt install rsync
I just verified that indeed a trailing slash is required at the source directory to copy the content instead of the directory. In dietpi-sync we also add it to the target directory, but I guess it is not necessarily required. If the target directory does not exist yet, I guess omitting both trailing slashes would work as well.
You can remove the old mountpoint:
rmdir /mnt/1627f155-5a19-4bc8-80ee-1e01ff08b8cb
Generally it would have been possible to do the /etc/fstab adjustment via dietpi-drive_manager, unmounting the old drive and mounting the new one to /mnt/media. Removal of the old mount point is then done automatically. But editing /etc/fstab of course works fine as well.
It is about 1 GiB as size. The unit is KiB :wink:. swapon -a works as well to re-enable the swap file, or just reboot. It is also in the /etc/fstab to be mounted at boot.
I saw here in order to copy the entire drive, symlinks and all
rsync -aAXv
How To Backup Your Entire Linux System Using Rsync - OSTechNix
  • -aAXv - The files are transferred in “archive” mode, which ensures that symbolic links, devices, permissions, ownerships, modification times, ACLs, and extended attributes are preserved.
@nicheplayer one last request from my side. Pls select one of the answers as solution and we could document it as solved :smiley:
