Any chance getting a motioneye update soon?
I have problems with firefox, which does not show the camera picture.
Update to 0.41 or 0.42 should fix it:
https://github.com/ccrisan/motioneye/issues/1694
many thanks for your report. As far as I can see Motioneye is installed without naming a specific version, directly using pip command
pip install motioneye
I did a quick installation of Motioneye on my RPi and I got motioneye-0.42.1
Collecting motioneye
Downloading motioneye-0.42.1.tar.gz (758 kB)
|████████████████████████████████| 758 kB 1.3 MB/s
To upgrade your system, you can follow instructions on Motioneye GitHub
https://github.com/ccrisan/motioneye/wiki/Installation#upgrading
It worked. Remarkable!
Didn’t know about that - game changer!
Thanks a lot!
yes, software title who are not installed via apt packages would need to be maintained manually, following software provider update installations
