Mjpg-Streamer on Rpi0
Hi MichaIng - thanks so much for your patience and help with this.
After a daemon-reload, I’m getting another error:
systemctl status mjpg-streamer
× mjpg-streamer.service - mjpg-streamer (DietPi)
     Loaded: loaded (/etc/systemd/system/mjpg-streamer.service; enabled; preset: enabled)
    Drop-In: /etc/systemd/system/mjpg-streamer.service.d
             └─dietpi-services_edit.conf
     Active: failed (Result: exit-code) since Sun 2024-03-10 23:16:18 GMT; 25s ago
   Duration: 204ms
       Docs: https://github.com/jacksonliam/mjpg-streamer/tree/master/mjpg-streamer-experimental
    Process: 1611 ExecStart=/opt/mjpg-streamer/mjpg_streamer -i input_uvc.so -d /dev/video0 -o output_http.so -p 8082 -n (code=exited, status=1/FAILURE)
   Main PID: 1611 (code=exited, status=1/FAILURE)
        CPU: 199ms
Mar 10 23:16:18 ZERO2CAM01 mjpg_streamer[1611]: Init v4L2 failed !! exit fatal
Mar 10 23:16:18 ZERO2CAM01 mjpg_streamer[1611]:  i: init_VideoIn failed
Mar 10 23:16:18 ZERO2CAM01 mjpg_streamer[1611]: MJPG-streamer [1611]: Using V4L2 device.: /dev/video0
Mar 10 23:16:18 ZERO2CAM01 mjpg_streamer[1611]: MJPG-streamer [1611]: Desired Resolution: 640 x 480
Mar 10 23:16:18 ZERO2CAM01 mjpg_streamer[1611]: MJPG-streamer [1611]: Frames Per Second.: -1
Mar 10 23:16:18 ZERO2CAM01 mjpg_streamer[1611]: MJPG-streamer [1611]: Format............: JPEG
Mar 10 23:16:18 ZERO2CAM01 mjpg_streamer[1611]: MJPG-streamer [1611]: TV-Norm...........: DEFAULT
Mar 10 23:16:18 ZERO2CAM01 systemd[1]: mjpg-streamer.service: Main process exited, code=exited, status=1/FAILURE
Mar 10 23:16:18 ZERO2CAM01 mjpg_streamer[1611]: MJPG-streamer [1611]: init_VideoIn failed
Mar 10 23:16:18 ZERO2CAM01 systemd[1]: mjpg-streamer.service: Failed with result 'exit-code'.
root@ZERO2CAM01:~#
Now one would need to find the correct /dev/video* device node. /dev/video0 is obviously not correct. But probably it works with none of them this way (getting MJPEG stream from one of the devices), but they may all require libcamera: https://www.raspberrypi.com/documentation/computers/camera_software.html#device-nodes-when-using-libcamera
I have a camera module 3 now as well, and will tinker with this when I find time.
