I typed those commands, though it didn’t to do anything. I believe it has something to do with the fact that I replaced my /etc/lighttpd folder with a backup of the old server. However, lighttpd can indeed read the files given.
It’s OK, though, as I have figured out my own solution for it in my previous reply. It may be a patch-like fix, but it’s something.
ok, good that it is working now, or at least you are back online witch your system. I will mark the issue as solved. Hope that’s fine with your.
