Hi Joulinar Can I just upgrade Mariadb?
I just remove /dietpi_userdata/mysql folder and now I can reinstall nextcloud but it don’t work also.
I see:
Internal Server Error
The server encountered an internal error and was unable to complete your request.
Please contact the server administrator if this error reappears multiple times, please include the technical details below in your report.
More details can be found in the server log.
on my https website. Http don’t work also.
When I try to fix with ncc command I see those errors:
root@DietPi:/# ncc
An unhandled exception has been thrown:
PDOException: SQLSTATE[42S02]: Base table or view not found: 1146 Table 'nextcloud.oc_appconfig' doesn't exist in /var/www/nextcloud/3rdparty/doctrine/dbal/src/Driver/PDO/Connection.php:82
Stack trace:
#0 /var/www/nextcloud/3rdparty/doctrine/dbal/src/Driver/PDO/Connection.php(82): PDO->query('SELECT * FROM `...')
#1 /var/www/nextcloud/3rdparty/doctrine/dbal/src/Connection.php(1035): Doctrine\DBAL\Driver\PDO\Connection->query('SELECT * FROM `...')
#2 /var/www/nextcloud/lib/private/DB/Connection.php(226): Doctrine\DBAL\Connection->executeQuery('SELECT * FROM `...', Array, Array, NULL)
#3 /var/www/nextcloud/3rdparty/doctrine/dbal/src/Query/QueryBuilder.php(210): OC\DB\Connection->executeQuery('SELECT * FROM `...', Array, Array)
#4 /var/www/nextcloud/lib/private/DB/QueryBuilder/QueryBuilder.php(287): Doctrine\DBAL\Query\QueryBuilder->execute()
#5 /var/www/nextcloud/lib/private/AppConfig.php(345): OC\DB\QueryBuilder\QueryBuilder->execute()
#6 /var/www/nextcloud/lib/private/AppConfig.php(110): OC\AppConfig->loadConfigValues()
#7 /var/www/nextcloud/lib/private/AppConfig.php(301): OC\AppConfig->getApps()
#8 /var/www/nextcloud/lib/private/legacy/OC_App.php(965): OC\AppConfig->getValues(false, 'installed_versi...')
#9 /var/www/nextcloud/lib/private/Server.php(682): OC_App::getAppVersions()
#10 /var/www/nextcloud/lib/private/AppFramework/Utility/SimpleContainer.php(155): OC\Server->OC\{closure}(Object(OC\Server))
#11 /var/www/nextcloud/3rdparty/pimple/pimple/src/Pimple/Container.php(118): OC\AppFramework\Utility\SimpleContainer->OC\AppFramework\Utility\{closure}(Object(Pimple\Container))
#12 /var/www/nextcloud/lib/private/AppFramework/Utility/SimpleContainer.php(122): Pimple\Container->offsetGet('OC\\Memcache\\Fac...')
#13 /var/www/nextcloud/lib/private/ServerContainer.php(137): OC\AppFramework\Utility\SimpleContainer->query('OC\\Memcache\\Fac...', false)
#14 /var/www/nextcloud/lib/private/AppFramework/Utility/SimpleContainer.php(56): OC\ServerContainer->query('OC\\Memcache\\Fac...')
#15 /var/www/nextcloud/lib/private/AppFramework/Utility/SimpleContainer.php(177): OC\AppFramework\Utility\SimpleContainer->get('OC\\Memcache\\Fac...')
#16 /var/www/nextcloud/lib/private/AppFramework/Utility/SimpleContainer.php(155): OC\AppFramework\Utility\SimpleContainer->OC\AppFramework\Utility\{closure}(Object(OC\Server))
#17 /var/www/nextcloud/3rdparty/pimple/pimple/src/Pimple/Container.php(114): OC\AppFramework\Utility\SimpleContainer->OC\AppFramework\Utility\{closure}(Object(Pimple\Container))
#18 /var/www/nextcloud/lib/private/AppFramework/Utility/SimpleContainer.php(122): Pimple\Container->offsetGet('OCP\\ICacheFacto...')
#19 /var/www/nextcloud/lib/private/ServerContainer.php(137): OC\AppFramework\Utility\SimpleContainer->query('OCP\\ICacheFacto...', false)
#20 /var/www/nextcloud/lib/private/AppFramework/Utility/SimpleContainer.php(56): OC\ServerContainer->query('OCP\\ICacheFacto...')
#21 /var/www/nextcloud/lib/private/Server.php(1041): OC\AppFramework\Utility\SimpleContainer->get('OCP\\ICacheFacto...')
#22 /var/www/nextcloud/lib/private/AppFramework/Utility/SimpleContainer.php(155): OC\Server->OC\{closure}(Object(OC\Server))
#23 /var/www/nextcloud/3rdparty/pimple/pimple/src/Pimple/Container.php(118): OC\AppFramework\Utility\SimpleContainer->OC\AppFramework\Utility\{closure}(Object(Pimple\Container))
#24 /var/www/nextcloud/lib/private/AppFramework/Utility/SimpleContainer.php(122): Pimple\Container->offsetGet('OCP\\Lock\\ILocki...')
#25 /var/www/nextcloud/lib/private/ServerContainer.php(137): OC\AppFramework\Utility\SimpleContainer->query('OCP\\Lock\\ILocki...', false)
#26 /var/www/nextcloud/lib/private/AppFramework/Utility/SimpleContainer.php(56): OC\ServerContainer->query('OCP\\Lock\\ILocki...')
#27 /var/www/nextcloud/lib/private/Server.php(2000): OC\AppFramework\Utility\SimpleContainer->get('OCP\\Lock\\ILocki...')
#28 /var/www/nextcloud/lib/private/Files/View.php(119): OC\Server->getLockingProvider()
#29 /var/www/nextcloud/lib/private/Server.php(430): OC\Files\View->__construct()
#30 /var/www/nextcloud/lib/private/AppFramework/Utility/SimpleContainer.php(155): OC\Server->OC\{closure}(Object(OC\Server))
#31 /var/www/nextcloud/3rdparty/pimple/pimple/src/Pimple/Container.php(118): OC\AppFramework\Utility\SimpleContainer->OC\AppFramework\Utility\{closure}(Object(Pimple\Container))
#32 /var/www/nextcloud/lib/private/AppFramework/Utility/SimpleContainer.php(122): Pimple\Container->offsetGet('OC\\Files\\Node\\H...')
#33 /var/www/nextcloud/lib/private/ServerContainer.php(137): OC\AppFramework\Utility\SimpleContainer->query('OC\\Files\\Node\\H...', false)
#34 /var/www/nextcloud/lib/private/AppFramework/Utility/SimpleContainer.php(56): OC\ServerContainer->query('OC\\Files\\Node\\H...')
#35 /var/www/nextcloud/lib/private/Server.php(1363): OC\AppFramework\Utility\SimpleContainer->get('OC\\Files\\Node\\H...')
#36 /var/www/nextcloud/lib/base.php(588): OC\Server->boot()
#37 /var/www/nextcloud/lib/base.php(1076): OC::init()
#38 /var/www/nextcloud/console.php(49): require_once('/var/www/nextcl...')
#39 /var/www/nextcloud/occ(11): require_once('/var/www/nextcl...')
#40 {main}
Next Doctrine\DBAL\Driver\PDO\Exception: SQLSTATE[42S02]: Base table or view not found: 1146 Table 'nextcloud.oc_appconfig' doesn't exist in /var/www/nextcloud/3rdparty/doctrine/dbal/src/Driver/PDO/Exception.php:26
Stack trace:
#0 /var/www/nextcloud/3rdparty/doctrine/dbal/src/Driver/PDO/Connection.php(87): Doctrine\DBAL\Driver\PDO\Exception::new(Object(PDOException))
#40 {main}
Next Doctrine\DBAL\Exception\TableNotFoundException: An exception occurred while executing a query: SQLSTATE[42S02]: Base table or view not found: 1146 Table 'nextcloud.oc_appconfig' doesn't exist in /var/www/nextcloud/3rdparty/doctrine/dbal/src/Driver/API/MySQL/ExceptionConverter.php:47
Stack trace:
#0 /var/www/nextcloud/3rdparty/doctrine/dbal/src/Connection.php(1728): Doctrine\DBAL\Driver\API\MySQL\ExceptionConverter->convert(Object(Doctrine\DBAL\Driver\PDO\Exception), Object(Doctrine\DBAL\Query))
#1 /var/www/nextcloud/3rdparty/doctrine/dbal/src/Connection.php(1667): Doctrine\DBAL\Connection->handleDriverException(Object(Doctrine\DBAL\Driver\PDO\Exception), Object(Doctrine\DBAL\Query))
#2 /var/www/nextcloud/3rdparty/doctrine/dbal/src/Connection.php(1040): Doctrine\DBAL\Connection->convertExceptionDuringQuery(Object(Doctrine\DBAL\Driver\PDO\Exception), 'SELECT * FROM `...', Array, Array)
#3 /var/www/nextcloud/lib/private/DB/Connection.php(226): Doctrine\DBAL\Connection->executeQuery('SELECT * FROM `...', Array, Array, NULL)
#4 /var/www/nextcloud/3rdparty/doctrine/dbal/src/Query/QueryBuilder.php(210): OC\DB\Connection->executeQuery('SELECT * FROM `...', Array, Array)
#5 /var/www/nextcloud/lib/private/DB/QueryBuilder/QueryBuilder.php(287): Doctrine\DBAL\Query\QueryBuilder->execute()
#6 /var/www/nextcloud/lib/private/AppConfig.php(345): OC\DB\QueryBuilder\QueryBuilder->execute()
#7 /var/www/nextcloud/lib/private/AppConfig.php(110): OC\AppConfig->loadConfigValues()
#8 /var/www/nextcloud/lib/private/AppConfig.php(301): OC\AppConfig->getApps()
#9 /var/www/nextcloud/lib/private/legacy/OC_App.php(965): OC\AppConfig->getValues(false, 'installed_versi...')
#10 /var/www/nextcloud/lib/private/Server.php(682): OC_App::getAppVersions()
#11 /var/www/nextcloud/lib/private/AppFramework/Utility/SimpleContainer.php(155): OC\Server->OC\{closure}(Object(OC\Server))
#12 /var/www/nextcloud/3rdparty/pimple/pimple/src/Pimple/Container.php(118): OC\AppFramework\Utility\SimpleContainer->OC\AppFramework\Utility\{closure}(Object(Pimple\Container))
#13 /var/www/nextcloud/lib/private/AppFramework/Utility/SimpleContainer.php(122): Pimple\Container->offsetGet('OC\\Memcache\\Fac...')
#14 /var/www/nextcloud/lib/private/ServerContainer.php(137): OC\AppFramework\Utility\SimpleContainer->query('OC\\Memcache\\Fac...', false)
#15 /var/www/nextcloud/lib/private/AppFramework/Utility/SimpleContainer.php(56): OC\ServerContainer->query('OC\\Memcache\\Fac...')
#16 /var/www/nextcloud/lib/private/AppFramework/Utility/SimpleContainer.php(177): OC\AppFramework\Utility\SimpleContainer->get('OC\\Memcache\\Fac...')
#17 /var/www/nextcloud/lib/private/AppFramework/Utility/SimpleContainer.php(155): OC\AppFramework\Utility\SimpleContainer->OC\AppFramework\Utility\{closure}(Object(OC\Server))
#18 /var/www/nextcloud/3rdparty/pimple/pimple/src/Pimple/Container.php(114): OC\AppFramework\Utility\SimpleContainer->OC\AppFramework\Utility\{closure}(Object(Pimple\Container))
#19 /var/www/nextcloud/lib/private/AppFramework/Utility/SimpleContainer.php(122): Pimple\Container->offsetGet('OCP\\ICacheFacto...')
#20 /var/www/nextcloud/lib/private/ServerContainer.php(137): OC\AppFramework\Utility\SimpleContainer->query('OCP\\ICacheFacto...', false)
#21 /var/www/nextcloud/lib/private/AppFramework/Utility/SimpleContainer.php(56): OC\ServerContainer->query('OCP\\ICacheFacto...')
#22 /var/www/nextcloud/lib/private/Server.php(1041): OC\AppFramework\Utility\SimpleContainer->get('OCP\\ICacheFacto...')
#23 /var/www/nextcloud/lib/private/AppFramework/Utility/SimpleContainer.php(155): OC\Server->OC\{closure}(Object(OC\Server))
#24 /var/www/nextcloud/3rdparty/pimple/pimple/src/Pimple/Container.php(118): OC\AppFramework\Utility\SimpleContainer->OC\AppFramework\Utility\{closure}(Object(Pimple\Container))
#25 /var/www/nextcloud/lib/private/AppFramework/Utility/SimpleContainer.php(122): Pimple\Container->offsetGet('OCP\\Lock\\ILocki...')
#26 /var/www/nextcloud/lib/private/ServerContainer.php(137): OC\AppFramework\Utility\SimpleContainer->query('OCP\\Lock\\ILocki...', false)
#27 /var/www/nextcloud/lib/private/AppFramework/Utility/SimpleContainer.php(56): OC\ServerContainer->query('OCP\\Lock\\ILocki...')
#28 /var/www/nextcloud/lib/private/Server.php(2000): OC\AppFramework\Utility\SimpleContainer->get('OCP\\Lock\\ILocki...')
#29 /var/www/nextcloud/lib/private/Files/View.php(119): OC\Server->getLockingProvider()
#30 /var/www/nextcloud/lib/private/Server.php(430): OC\Files\View->__construct()
#31 /var/www/nextcloud/lib/private/AppFramework/Utility/SimpleContainer.php(155): OC\Server->OC\{closure}(Object(OC\Server))
#32 /var/www/nextcloud/3rdparty/pimple/pimple/src/Pimple/Container.php(118): OC\AppFramework\Utility\SimpleContainer->OC\AppFramework\Utility\{closure}(Object(Pimple\Container))
#33 /var/www/nextcloud/lib/private/AppFramework/Utility/SimpleContainer.php(122): Pimple\Container->offsetGet('OC\\Files\\Node\\H...')
#34 /var/www/nextcloud/lib/private/ServerContainer.php(137): OC\AppFramework\Utility\SimpleContainer->query('OC\\Files\\Node\\H...', false)
#35 /var/www/nextcloud/lib/private/AppFramework/Utility/SimpleContainer.php(56): OC\ServerContainer->query('OC\\Files\\Node\\H...')
#36 /var/www/nextcloud/lib/private/Server.php(1363): OC\AppFramework\Utility\SimpleContainer->get('OC\\Files\\Node\\H...')
#37 /var/www/nextcloud/lib/base.php(588): OC\Server->boot()
#38 /var/www/nextcloud/lib/base.php(1076): OC::init()
#39 /var/www/nextcloud/console.php(49): require_once('/var/www/nextcl...')
#40 /var/www/nextcloud/occ(11): require_once('/var/www/nextcl...')
#41 {main}root@DietPi:/#
Regards
