Let's encrypt help
  • Kernel version | uname -a
  1. …new install
  2. …phpbb and let’s encrypt setup as usual
    Portal 80 and 443
  • …port connects ok
    Port 443 doesnt
you can connect via http but not via https? Did you get some error message when you try https?
Can you share listen ports
ss -tulpn | grep LISTEN
Listening on port 80 and 443
Port 80 works fine
Port 443 with SSL certificate doesn’t work
I had issues with loopback Wich is new this week only.solved it by using on a VPN on client machine
That worked for about a day then nothing worked.
So I followed this guide “https://certbot.eff.org/” and got it working again but I still have to use a VPN.
I’m with fizz ISP they never blocked loopback before.
Now my only issue is how to access within same network .do u have any tips I’m not sure but would reverse proxy work and how do I use it from dietpi saware list thanks for the response.
if using a VPN, you would not need SSL. The VPN connection is already encrypted, and SSL is not bringing any additional security. SSL makes sense if you don’t use a VPN connection.
Are you able to connect from extern using HTTPS + DDNS without any VPN?
Are you able to connect directly from intern using HTTPS + local IP?
Does port forwarding on your router has been setup correctly for 80 + 443?
Port 80 works fine
So I followed this guide “| Certbot and got it working again but I still have to use a VPN.
Router ports r setup 80 and 443
I tried like u said without a VPN
And local IP with https and it does not work.
But if I use my phone mobile data instead of home network it connect fine and google says it’s secure with tls
Ok I can connect locally with IP and https but says it’s not secure google intercepted with a security warning I had to click proceed anyway for the site to open
Here is my address exrestv.duckdns.org/forum - Index page
Means it is working from extern
as expected, as the certificate is valid for your domain but no for an IP
OK the issue is: you are not able to access your DDNS from inside of your network, while accessing it from extern is working. Right.
This is an issue of your router. I have same on my router. Solution for me is to use an own DNS server inside my local network who redirect me internally.
I understand the concept make perfect sense.
I just don’t know how to create an Internal DNS.lol
Thanks for your help
I will look up how to do it on Google or do u have a guide for me
I use PiHole (available as DietPi software option) as internal DNS. It has the benefit of blocking Ads and resolving my DDNS internally.
Just realized that I can access it with port 80 http
Internally so DNS should be working fine correct
Still your router needs to forward/redirect you on port 443. Maybe that’s where the router is having a challenge with.
