I installed Kavita Reader on a Dietpi 8.15. The first time I launched it, everything went fine. Then after the first reboot, it is impossible to launch it.
I get the result shown in image 1.
Then when I dig into the source code, I see that everything is in a Nextcloud directory that I did not install. Like image 2.
I’m using LXQT and I’ve programmed Autostart Kavita so that it launches on every boot. I think that’s where it comes from.
The programmers saw a buggy JSON, but when I check it everything is valid. They asked me to clear the Token, which I did, and restart, which I did, but it doesn’t work.
I think it’s all from the LXQT autostart. The problem is that when I remove the autostart and run it manually, the bug persists.
What do I have to unblock to reactivate Kavita?
Thank you for your help.
Good day to all.
Translated with DeepL Translate: The world's most accurate translator (free version)
