Issue using python3 venv module
  • DietPi version:
    G_DIETPI_VERSION_CORE=9
    G_DIETPI_VERSION_SUB=8
  • Distro version
    bookworm 0
python3
Context: I want to automate my rpi5 installation using dietpi first boot text file and post installation script.
So I used the automatic dietpi installation and installed the software:
130 Python 3: Runtime system, pip package installer and development headers
And then I try to run the script:
#!/bin/bash
# Script to execute after dietpi
# initial installation.
dir_location=/opt/shared
mkdir $dir_location; cd $dir_location && python3 -m venv env && env/bin/python3 -m pip install requests
I expect the virtual environment env to be created and usable.
I have the error:
The virtual environment was not created successfully because ensurepip is not
available. On Debian/Ubuntu systems, you need to install the python3-venv
package using the following command.
apt install python3.11-venv
You may need to use sudo with that command. After installing the python3-venv
package, recreate your virtual environment.
Failing command: /opt/shared/env/bin/python3
How I could avoid this issue / fully automate my venv creation?
Sincerely
Does it work from CLI? If yes, maybe try to call python with an absolute path from inside the script.
mkdir $dir_location; cd $dir_location && /usr/bin/python3 -m venv env && env/bin/python3 -m pip install requests
By default, we only install the Python packages and do not create a virtual environment right at the start. For some applications such as HA, we create our own virtual environment via pyenv during the installation.
If you need the packet python3.11-venv right from the start, you would have to install it via the ‘post-DietPi’ install script.
I did it and indeed it worked, thanks for the support :slight_smile:
