After the weekend the influxdb stop working and it’s taking a lot os process power.
I would like to try repair the installation or downgrade but I could find how.
If anyone knows what could be , please help me.
I stooped the service because it was slowing the Raspberry Pi server.
- DietPi v7.9.4 (stretch) :
- Device model : RPi 3 Model B (armv7l)
- Power supply used: 5V 3A
- SD card used: SanDisk ultra
- Software title: Influxdb
- Was the software title installed freshly or updated/migrated? Update
I don’t know, just happen during the weekend without doing nothing
- Should be
- influxdb is using a lot os process power
journalctl -u influxdb
-- Logs begin at Thu 2016-11-03 15:16:42 -02, end at Mon 2022-10-24 14:21:32 -03. --
out 24 13:01:55 ServidorPi systemd[1]: Starting InfluxDB is an open-source, distributed, time series database...
out 24 13:01:57 ServidorPi influxd-systemd-start.sh[576]: Merging with configuration at: /etc/influxdb/influxdb.conf
out 24 13:01:57 ServidorPi influxd-systemd-start.sh[576]: ts=2022-10-24T16:01:57.673083Z lvl=info msg="InfluxDB starting" log_id=0djgWJfG000 version=1.8.10 branch=1.8 commit=688e697c51fd
out 24 13:01:57 ServidorPi influxd-systemd-start.sh[576]: ts=2022-10-24T16:01:57.673216Z lvl=info msg="Go runtime" log_id=0djgWJfG000 version=go1.13.8 maxprocs=4
out 24 13:01:57 ServidorPi influxd-systemd-start.sh[576]: ts=2022-10-24T16:01:57.815458Z lvl=info msg="Using data dir" log_id=0djgWJfG000 service=store path=/var/lib/influxdb/data
out 24 13:01:57 ServidorPi influxd-systemd-start.sh[576]: ts=2022-10-24T16:01:57.815680Z lvl=info msg="Compaction settings" log_id=0djgWJfG000 service=store max_concurrent_compactions=2 throughput_bytes_per_second=50331648 throughput_bytes_per_second_burst=50331648
out 24 13:01:57 ServidorPi influxd-systemd-start.sh[576]: ts=2022-10-24T16:01:57.815753Z lvl=info msg="Open store (start)" log_id=0djgWJfG000 service=store trace_id=0djgWKDl000 op_name=tsdb_open op_event=start
out 24 13:01:57 ServidorPi influxd-systemd-start.sh[576]: InfluxDB API unavailable after 1 attempts...
out 24 13:01:58 ServidorPi influxd-systemd-start.sh[576]: ts=2022-10-24T16:01:58.204838Z lvl=info msg="Opened file" log_id=0djgWJfG000 engine=tsm1 service=filestore path=/var/lib/influxdb/data/Yamaguchi/autogen/1001/000000003-000000003.tsm id=0 duration=20.089ms
out 24 13:01:58 ServidorPi influxd-systemd-start.sh[576]: ts=2022-10-24T16:01:58.201575Z lvl=info msg="Opened file" log_id=0djgWJfG000 engine=tsm1 service=filestore path=/var/lib/influxdb/data/Yamaguchi/autogen/993/000000003-000000004.tsm id=0 duration=16.576ms
out 24 13:01:58 ServidorPi influxd-systemd-start.sh[576]: ts=2022-10-24T16:01:58.203680Z lvl=info msg="Opened file" log_id=0djgWJfG000 engine=tsm1 service=filestore path=/var/lib/influxdb/data/Yamaguchi/autogen/1009/000000002-000000003.tsm id=0 duration=18.317ms
out 24 13:01:58 ServidorPi influxd-systemd-start.sh[576]: ts=2022-10-24T16:01:58.208090Z lvl=info msg="Opened file" log_id=0djgWJfG000 engine=tsm1 service=filestore path=/var/lib/influxdb/data/Yamaguchi/autogen/1017/000000001-000000002.tsm id=0 duration=22.325ms
out 24 13:01:58 ServidorPi influxd-systemd-start.sh[576]: ts=2022-10-24T16:01:58.591764Z lvl=info msg="Opened shard" log_id=0djgWJfG000 service=store trace_id=0djgWKDl000 op_name=tsdb_open index_version=inmem path=/var/lib/influxdb/data/Yamaguchi/autogen/1001 duration=478.782ms
