# Help with booting problem Rpi4 and Ssd
**URL:** https://dietpi.com/forum/t/help-with-booting-problem-rpi4-and-ssd/3589
**Category:** Troubleshooting
**Created:** [9 November 2019 14:50 UTC](https://dietpi.com/forum/t/help-with-booting-problem-rpi4-and-ssd/3589 "2019-11-09T14:50:53Z")
**Posts on this page:** 12
**Page:** 1
<div class="post-metadata">
### Author: ![DutchFlash](https://dietpi.com/forum/user_avatar/dietpi.com/dutchflash/32/35_2.png) [@DutchFlash](https://dietpi.com/forum/u/DutchFlash)
#### Post date: [9 November 2019 14:50 UTC](https://dietpi.com/forum/t/help-with-booting-problem-rpi4-and-ssd/3589/1 "2019-11-09T14:50:53Z")
</div>
Where can i download a older version of dietpi ?
Dietpi versie 6.26.3 give me errors.
Clean install op rpi4.
With the older versions, i had never problems before.
My problem with dietpi 6.26.3 I cant use a Ssd or Hd to boot dietpi.
RootFS on Sd card oke, but RootFS to ssd or hd then get error when booting up.
[![](https://i.ibb.co/5sVg2dg/2019-11-07-21-02-16.jpg)](https://ibb.co/5sVg2dg)
Give root password for maintenance
(or press Control-D to continue): \_
**When press control D, I get:**
(or press Control-D to continue): Sulogin: cannot read /dev/tty1: Operation not permitted
Please help me with this problem 😢😢😢😢😢😢
p.s.
sorry for my english(i’am dutch)
DutchFlash
#### Post date: [11 November 2019 20:00 UTC](https://dietpi.com/forum/t/help-with-booting-problem-rpi4-and-ssd/3589/2 "2019-11-11T20:00:25Z")
</div>
Nobody can help me ? 😢😢😢
### Author: ![MichaIng](https://dietpi.com/forum/user_avatar/dietpi.com/michaing/32/7_2.png) [@MichaIng](https://dietpi.com/forum/u/MichaIng)
#### Post date: [11 November 2019 20:11 UTC](https://dietpi.com/forum/t/help-with-booting-problem-rpi4-and-ssd/3589/3 "2019-11-11T20:11:01Z")
</div>
It fails to mount the boot partition from SDcard. Note that you cannot remove it, as long as root partition is on external drive only, and RPi4 does not support USB boot anyway currently.
How did you transfer the roof partition?
#### Post date: [11 November 2019 22:34 UTC](https://dietpi.com/forum/t/help-with-booting-problem-rpi4-and-ssd/3589/4 "2019-11-11T22:34:49Z")
</div>
Roof partition ?
I do Transfer RootFS to this drive , Then i choice the drive(sda5).And after a few second it’s copie from sd to ssd.
I did this always with previous vesions and that works fine.
p.s.
I leave the sd card in de rpi.
#### Post date: [12 November 2019 20:37 UTC](https://dietpi.com/forum/t/help-with-booting-problem-rpi4-and-ssd/3589/5 "2019-11-12T20:37:06Z")
</div>
I have an idea what might be the issue. With v6.22 we made a change to not forcefully reboot the system after moving the rootfs, but give user the choice whether to reboot now or later. But actually that was not thought through, since other mount options can lead to fstab rewrite which then writes back the old (currently active) rootfs entry. In such case cmdline.txt has the new rootfs entry while fstab has the old one which most likely causes some issue when systemd wants to remount it.
Is it probably the case the you skipped reboot first after moving rootfs?
If so do you have an external Linux system to mount the external drive to? If so edit the etc/fstab on that drive and adjust the root mount entry so that mount source is:
PARTUUID=\<PARTUUID\_of\_that\_partition\>.
To get the PARTUUID: lsblk -no PARTUUID /dev/sda1 (with /dev/sda1 being the external rootfs partition)
This should match the entry in cmdline.txt from SDcard boot partition as well.
The fstab entry could then e.g. look like this:
PARTUUID=a277a2ba-02 / ext4 noatime,lazytime 0 1
The cmdline.txt contains matching:
root=PARTUUID=a277a2ba-02
I just reverted the change from v6.22, so a reboot is now forced again once RootFS transfer has finished: [https://github.com/MichaIng/DietPi/commit/b79bb9e3de863bfb7d01c69b6f3a5f798f839ad8](https://github.com/MichaIng/DietPi/commit/b79bb9e3de863bfb7d01c69b6f3a5f798f839ad8)
Changelog: [https://github.com/MichaIng/DietPi/commit/482ed82e754f3cdcc20ba2cbdc4b183db8822d6e](https://github.com/MichaIng/DietPi/commit/482ed82e754f3cdcc20ba2cbdc4b183db8822d6e)
#### Post date: [13 November 2019 09:39 UTC](https://dietpi.com/forum/t/help-with-booting-problem-rpi4-and-ssd/3589/6 "2019-11-13T09:39:53Z")
</div>
> I just reverted the change from v6.22, so a reboot is now forced again once RootFS transfer has finished: [v6.27 · MichaIng/DietPi@b79bb9e · GitHub](https://github.com/MichaIng/DietPi/commit/b79bb9e3de863bfb7d01c69b6f3a5f798f839ad8)
> Changelog: [v6.27 · MichaIng/DietPi@482ed82 · GitHub](https://github.com/MichaIng/DietPi/commit/482ed82e754f3cdcc20ba2cbdc4b183db8822d6e)
No i press restarting after transferFS
And i have no external linux system, I can’t figure this out, this goes too far for me.
I’am a **NEWBIE**
Can i get a link(url) for a older dietpi version ? that will help me.
If not then i must look for a other os then 😢
Or i wait on dietpi 6.27/6.28 ? Maby there will be a solution
p.s.
Tnx for the help…
### Author: ![ZeroZorro](https://dietpi.com/forum/letter_avatar_proxy/v4/letter/z/d9b06d/32.png) [@ZeroZorro](https://dietpi.com/forum/u/ZeroZorro)
#### Post date: [13 November 2019 14:59 UTC](https://dietpi.com/forum/t/help-with-booting-problem-rpi4-and-ssd/3589/7 "2019-11-13T14:59:42Z")
</div>
hi, i experienced same problem.
Fresh install on RPI4, dietpi-update, and reboot direct after moving RootFS
First nothing at all, but cause i was not nearby device i left it alone.
After 1 hour i logged in again (don’t ask me why) and low and behold: i could log in with putty again!
So maybe you can give it another try ?
/etc/fstab and /boot/cmdline.txt seem to have the right PARTUUID
I can see with dietpi-drive manager that mount target is ‘/’ and mount source is on /dev/sda1
Also i can see that it says:
dev/mmcblk0p2 | ext4 | Not mounted
I dont know if that is like it should be…but will wait to reboot again after i got home 🙂
#### Post date: [13 November 2019 15:24 UTC](https://dietpi.com/forum/t/help-with-booting-problem-rpi4-and-ssd/3589/8 "2019-11-13T15:24:29Z")
</div>
I will give it a try, let you no how it’s go.
No go,Wait 1 hour.
Cant log in with putty 😢
I pull my hair out of my head 🤨
#### Post date: [14 November 2019 15:42 UTC](https://dietpi.com/forum/t/help-with-booting-problem-rpi4-and-ssd/3589/9 "2019-11-14T15:42:18Z")
</div>
Hi all,
**I succeeded** 😃🙂🕶
Found something on another site.
[https://www.raspberrypi.org/forums/viewtopic.php?f=29&t=196778&hilit=transfer+root+to+usb](https://www.raspberrypi.org/forums/viewtopic.php?f=29&t=196778&hilit=transfer+root+to+usb)
And it’s works. Dont ask me how 😛
You simply place the script in your home directory (‘pi’) and run it manually:
sudo ./usb-boot
And now RootFS is runnig on usb(ssd)
We happy again, raspberry pi 4 is up and running. Fs on usb(Ssd)
#### Post date: [20 November 2019 17:16 UTC](https://dietpi.com/forum/t/help-with-booting-problem-rpi4-and-ssd/3589/10 "2019-11-20T17:16:40Z")
</div>
DutchFlash
Thanks for sharing. For now I can’t see a difference between the methods the script uses and dietpi-drive\_manager uses. Will run some tests and check more closely 🤔.
EDIT: I have an idea!
Since you formated the one partition only instead of the whole drive, which partition table did it have? I am not sure if GPT partition table is supported by the RPi4 bootloader. With RPi3 it seems to be possible though: [https://www.raspberrypi.org/forums/viewtopic.php?t=205418](https://www.raspberrypi.org/forums/viewtopic.php?t=205418)
The usb-boot script clears and recreates the partition table for the whole drive with fdisk, hence it will be MBR by default. When using dietpi-drive\_manager to be failsafe, select Format Mode: Drive and Partition Type: MBR. Probably it was not required on previous RPi models but RPi4 came with a vast bootloader rewrite (now stored on an internal EEPROM), hence even that it is newer, possibly it still lacks some features. Futher investigation required if a fresh MBR partition table fails as well.
#### Post date: [20 November 2019 18:26 UTC](https://dietpi.com/forum/t/help-with-booting-problem-rpi4-and-ssd/3589/11 "2019-11-20T18:26:51Z")
</div>
> @DutchFlash
Your welcome 🕶
Tell use the resluit off the tests please 😃
#### Post date: [20 November 2019 19:05 UTC](https://dietpi.com/forum/t/help-with-booting-problem-rpi4-and-ssd/3589/12 "2019-11-20T19:05:44Z")
</div>
DutchFlash
I have an idea, after reviewing usb-boot and our script/method!
Since you formated the one partition only instead of the whole drive, which partition table did it have? I am not sure if GPT partition table is supported by the RPi4 bootloader. With RPi3 it seems to be [EDIT: NOT!] possible: [https://www.raspberrypi.org/forums/viewtopic.php?t=205418](https://www.raspberrypi.org/forums/viewtopic.php?t=205418)
The usb-boot script clears and recreates the partition table for the whole drive with fdisk, hence it will be MBR by default. When using dietpi-drive\_manager to be failsafe, select Format Mode: Drive and Partition Type: MBR. The RPi4 comes with a vast bootloader rewrite (now stored on an internal EEPROM), hence even that it is newer, but possibly it still lacks this features. Futher investigation required if a fresh MBR partition table fails as well.
Okay it seems to need to add this info to our script + set default entries accordingly:
- Format Mode: Drive
- Partition Type: MBR
- Filesystem Type: ext4 or f2fs
