Help with Bluetooth
Hi! I’m experiencing some issues while using a node red node that takes advantage of Bluetooth. For that I’m using the internal pi 4b Bluetooth and, as you can see in the attached screenshot, it’s behaving quite odd by connecting and disconnecting quite often.
It’s a LE device but it’s really close to it so distance is not the issue.
Thank you!
could you share following pls
journalctl -u bluetooth -u hciuart
