Not my first go around with DietPI but it is my first time trying to get Home Assistant and Node-Red running on a single RP3.
So i first installed Home Assistant using DP installer. This worked great! After configuring some devices in HA I then tried to update Python as the version DP installs is old and doesn’t support a Roku device I was trying to use, among others. I attempted to update Python and had no luck which was probably my fault but I finally gave up, removed the DietPI HA and installed Python3 from scratch along with HA into a virtual Python3 environment (similar to the DP HA install). All was great.
And then looked at installing Node-Red. I saw there was a DP package but I thought I may as well just install this myself too, since HA was also installed outside DP at this point. So I started to follow the instructions here - https://nodered.org/docs/getting-started/raspberrypi. That ended quickly when the script came back and said please installed using DP installer. Soooooo I installed DP Node-Red. For some reason DP install Python 2.x again. UGH, HA / Roku broken again. So I manually removed Python 2.x only and HA / Roku was again happy. I then checked on Node-Red and all appears good. So I have a bastardized hyrid install.
I guess what I am hoping to get out of this post is some understanding. Understanding as to why python is installed with these apps rather than as a stand alone install and why when a newer version of python is already installed does DP not notice and at least offer to use it? What am I missing here. Is this strictly to newbie proof the DP app installs? I realize it takes time to update all these installers so I am not complaining as I can work around the issues, just trying to see if I am being a total idiot here or missing something obvious.
