Error upgrade to Debian Trixie
I followed this steps.
root@DietPi:~# df
Dateisystem           1K-Blöcke    Benutzt  Verfügbar Verw% Eingehängt auf
/dev/root             118512728   21126996   92548732   19% /
devtmpfs                1935720          0    1935720    0% /dev
tmpfs                   1969512      14804    1954708    1% /dev/shm
tmpfs                    787808      74728     713080   10% /run
tmpfs                      5120          0       5120    0% /run/lock
tmpfs                      1024          0       1024    0% /run/credentials/systemd-journald.service
tmpfs                   1968128          8    1968120    1% /tmp
tmpfs                     51200         64      51136    1% /var/log
tmpfs                      1024          0       1024    0% /run/credentials/getty@tty1.service
//10.1.1.200/public 17263253948 7838171560 9425082388   46% /mnt/samba
/dev/sda1                258095      53322     204773   21% /boot/firmware
root@DietPi:~# cat /etc/fstab
# NETWORK
//10.1.1.200/public /mnt/samba cifs cred=/var/lib/dietpi/dietpi-drive_manager/mnt-samba.cred,iocharset=utf8,uid=dietpi,gid=dietpi,file_mode=0770,dir_mode=0770,vers=3.1.1,nofail,noauto,x-systemd.automount
# TMPFS
tmpfs /tmp tmpfs size=1922M,noatime,lazytime,nodev,nosuid,mode=1777
tmpfs /var/log tmpfs size=50M,noatime,lazytime,nodev,nosuid
# MISC: ecryptfs, vboxsf, glusterfs, mergerfs, bind, Btrfs subvolume
# SWAP SPACE
# PHYSICAL DRIVES
PARTUUID=8f4dbd00-02 / ext4 noatime,lazytime,rw 0 1
PARTUUID=8f4dbd00-01 /boot/firmware vfat noatime,lazytime,rw 0 2
root@DietPi:~# ls -l /boot /boot/firmware
/boot:
insgesamt 19418
lrwxrwxrwx 1 root root      20  5. Sep 17:16 cmdline.txt -> firmware/cmdline.txt
-rw-r--r-- 1 root root  249115 26. Jun 11:35 config-6.12.34+rpt-rpi-2712
-rwxr-xr-x 1 root root  249091 26. Jun 11:35 config-6.12.34+rpt-rpi-v8
lrwxrwxrwx 1 root root      19  5. Sep 17:16 config.txt -> firmware/config.txt
drwxr-xr-x 4 root root    4096 30. Aug 15:23 dietpi
-rw-r--r-- 1 root root   13252  1. Apr 2024  dietpi.txt
-rwxr-xr-x 1 root root    3950  1. Jan 1980  dietpi-wifi.txt
drwxr-xr-x 4 root root    5632  1. Jan 1970  firmware
-rw-r--r-- 1 root root      83 26. Jun 11:35 System.map-6.12.34+rpt-rpi-2712
-rwxr-xr-x 1 root root      83 26. Jun 11:35 System.map-6.12.34+rpt-rpi-v8
-rw-r--r-- 1 root root 9674342 26. Jun 11:35 vmlinuz-6.12.34+rpt-rpi-2712
-rwxr-xr-x 1 root root 9666917 26. Jun 11:35 vmlinuz-6.12.34+rpt-rpi-v8
/boot/firmware:
insgesamt 52107
-rwxr-xr-x 1 root root   23946  1. Okt 2019  bcm2708-rpi-b.dtb
-rwxr-xr-x 1 root root   24205  1. Okt 2019  bcm2708-rpi-b-plus.dtb
-rwxr-xr-x 1 root root   23723  1. Okt 2019  bcm2708-rpi-cm.dtb
-rwxr-xr-x 1 root root   23671  1. Okt 2019  bcm2708-rpi-zero.dtb
-rwxr-xr-x 1 root root   24407  1. Okt 2019  bcm2708-rpi-zero-w.dtb
-rwxr-xr-x 1 root root   25293  1. Okt 2019  bcm2709-rpi-2-b.dtb
-rwxr-xr-x 1 root root   32495 26. Jun 11:35 bcm2710-rpi-2-b.dtb
-rwxr-xr-x 1 root root   34687 26. Jun 11:35 bcm2710-rpi-3-b.dtb
-rwxr-xr-x 1 root root   35322 26. Jun 11:35 bcm2710-rpi-3-b-plus.dtb
-rwxr-xr-x 1 root root   33676 26. Jun 11:35 bcm2710-rpi-cm0.dtb
-rwxr-xr-x 1 root root   32258 26. Jun 11:35 bcm2710-rpi-cm3.dtb
-rwxr-xr-x 1 root root   33664 26. Jun 11:35 bcm2710-rpi-zero-2.dtb
-rwxr-xr-x 1 root root   33664 26. Jun 11:35 bcm2710-rpi-zero-2-w.dtb
-rwxr-xr-x 1 root root   56243 26. Jun 11:35 bcm2711-rpi-400.dtb
-rwxr-xr-x 1 root root   56239 26. Jun 11:35 bcm2711-rpi-4-b.dtb
-rwxr-xr-x 1 root root   56760 26. Jun 11:35 bcm2711-rpi-cm4.dtb
-rwxr-xr-x 1 root root   39913 26. Jun 11:35 bcm2711-rpi-cm4-io.dtb
-rwxr-xr-x 1 root root   53502 26. Jun 11:35 bcm2711-rpi-cm4s.dtb
-rwxr-xr-x 1 root root   78439 26. Jun 11:35 bcm2712d0-rpi-5-b.dtb
-rwxr-xr-x 1 root root   78431 26. Jun 11:35 bcm2712-d-rpi-5-b.dtb
-rwxr-xr-x 1 root root   78391 26. Jun 11:35 bcm2712-rpi-500.dtb
-rwxr-xr-x 1 root root   78435 26. Jun 11:35 bcm2712-rpi-5-b.dtb
-rwxr-xr-x 1 root root   79149 26. Jun 11:35 bcm2712-rpi-cm5-cm4io.dtb
-rwxr-xr-x 1 root root   79215 26. Jun 11:35 bcm2712-rpi-cm5-cm5io.dtb
-rwxr-xr-x 1 root root   79190 26. Jun 11:35 bcm2712-rpi-cm5l-cm4io.dtb
-rwxr-xr-x 1 root root   79256 26. Jun 11:35 bcm2712-rpi-cm5l-cm5io.dtb
-rwxr-xr-x 1 root root   52476 30. Aug 16:16 bootcode.bin
-rwxr-xr-x 1 root root     142 26. Sep 2023  cmdline.txt
-rwxr-xr-x 1 root root    1601 23. Jun 23:14 config.txt
drwxr-xr-x 2 root root     512  1. Mai 11:57 firmware
-rwxr-xr-x 1 root root    3230 30. Aug 16:16 fixup4cd.dat
-rwxr-xr-x 1 root root    5456 30. Aug 16:16 fixup4.dat
-rwxr-xr-x 1 root root    8449 30. Aug 16:16 fixup4db.dat
-rwxr-xr-x 1 root root    8449 30. Aug 16:16 fixup4x.dat
-rwxr-xr-x 1 root root    3230 30. Aug 16:16 fixup_cd.dat
-rwxr-xr-x 1 root root    7325 30. Aug 16:16 fixup.dat
-rwxr-xr-x 1 root root   10294 30. Aug 16:16 fixup_db.dat
-rwxr-xr-x 1 root root   10290 30. Aug 16:16 fixup_x.dat
-rwxr-xr-x 1 root root     145 13. Nov 2018  issue.txt
-rwxr-xr-x 1 root root 9674342  5. Sep 17:18 kernel_2712.img
-rwxr-xr-x 1 root root 5310800  1. Okt 2019  kernel7.img
-rwxr-xr-x 1 root root 9666917 30. Aug 17:01 kernel8.img
-rwxr-xr-x 1 root root 5026968  1. Okt 2019  kernel.img
-rwxr-xr-x 1 root root    1594 30. Aug 16:16 LICENCE.broadcom
-rwxr-xr-x 1 root root   18974 13. Nov 2018  LICENSE.oracle
drwxr-xr-x 2 root root   32768  4. Jul 14:24 overlays
-rwxr-xr-x 1 root root  814140 30. Aug 16:16 start4cd.elf
-rwxr-xr-x 1 root root 3762408 30. Aug 16:16 start4db.elf
-rwxr-xr-x 1 root root 2263968 30. Aug 16:16 start4.elf
-rwxr-xr-x 1 root root 3011592 30. Aug 16:16 start4x.elf
-rwxr-xr-x 1 root root  814140 30. Aug 16:16 start_cd.elf
-rwxr-xr-x 1 root root 4834408 30. Aug 16:16 start_db.elf
-rwxr-xr-x 1 root root 2988128 30. Aug 16:16 start.elf
-rwxr-xr-x 1 root root 3735336 30. Aug 16:16 start_x.elf
