again thank you for the really well done networking guide  ![]()
OK looking at my dietpi-ddns, looks like I’ve already done this:
    Provider : [No-IP]                                                 │
│           Domains  : [mydomain.ddns.net]                                │
│           Username : [myemail@gmail.com]                                 │
│           Password : [************]                                          │
│           Timespan : [10 minutes]
And reading what you wrote this is fine, but my question is: what happens if the dietpi is down and I’m using just this setting? I guess I can’t reach just mydomain.ddns.net, but all the other devices (such as a security camera) can be reached. Isn’t it?
I understand this, in my case the DNS root name server is No-ip. Is this correct?
Now, back to my pi-hole situation.
I don’t remember why (I’m quite sure there is a why
 ) When I was trying to reach the domain from my own network (with the old router), with the community we workaround in this way:
see this post [Solved]How to connect outside of dietpi network - #50 by Joulinar and this one [Solved]How to connect outside of dietpi network - #57 by Joulinar
This situation sounds good because, I think, this speeds up the internal connection. But, what if dietpi is down? does this mean all the devices connected to the router are unreachable?
So the final question now is: How can I check if going back to the easiest situation (i.e. just dietpi-ddns) without using pi-hole as a “DNS Resolver”, will work?
Siome last informations about my actual router that can, maybe, help:
In the configuration, I can see and change if every single device has DHCP or dedicated IP; I have a remote control panel where I can activate “HTTP: 8080 and HTTPS: 8181” to a single device, or range of IP’s addresses or to all the devices; I have a “port triggering” for which I ignore the function; I have a DMZ which is actually active and settled on the Dietpi address; I also have set (as suggested) the DHCP interval with a single IP address, the Dietpi ones.
