Dietpi/Plex installation, help please.
Hi guys,
Just installed Dietpi/Plex on the new Pi 4/Hifiberry digi+ aiming to send music thro’ Plex from Pi/Hifiberry digi coaxial to external DAC (Schiit Bifrost) then to the hifi rack.
When I open Plex on Chrome I can listen to the music thro’ laptop’s speaker/headphone and also works on ipad etc.
But I just don’t have audio out from Pi’s 3.5mm jack or Hifiberry’s coaxial at all!
Tried the config output to 3.5mm jack and Hifiberry, none of them work.
What do I need to do to get audio from Pi? Please help, much appreciated.
Alan
Are you selecting the Chrome instance as the player?
Top right corner there’s an icon inbetween the settings icon and your user avatar
Click that and see if there’s another player available (mine’s offline at the moment but is usually called Chrome Plex)
I think Plex usually defaults to playing through the ‘local’ player unless told otherwise.
there is only one option, …cast
that I have nothing to cast to
