Hello
would it be possible to update the program Deluge?
I also have a problem with the unpacker plug in deluge. It does not unpack my files in the specified directory.
I have also re-created Dietpi several times, but the problem remains.
Hello
Many thanks for your report.
We install Deluge from official repo, if you run a Stretch system and there is a Buster image available, consider to switch to have more current software packages.
About the extraction issue, could you go more into detail? Which archives exactly fail to extract, are there any error messages you can paste?
