curl: error while loading shared libraries
Out of curiosity. Would it be possible to activate WiFi and try to use it?
Yes, I will; first sleep a few hours.
Thanks for everything, until then.
@Joulinar:
it gave me no peace; Wi-Fi works! I can now access the system again with ssh:
Using username "root".
Linux DietPi 5.10.60-v7+ #1449 SMP Wed Aug 25 15:00:01 BST 2021 armv7l
The programs included with the Debian GNU/Linux system are free software;
the exact distribution terms for each program are described in the
individual files in /usr/share/doc/*/copyright.
Debian GNU/Linux comes with ABSOLUTELY NO WARRANTY, to the extent
permitted by applicable law.
Last login: Sat Sep 18 00:29:08 2021
 DietPi v7.6.1 (beta) : 00:37 - Sa 18.09.2021
 - Device model : RPi 3 Model B (armv7l)
 - Uptime : up 10 minutes
 - CPU temp : 45'C : 113'F (Optimal temperature)
 - LAN IP : 192.168.115.143 (wlan0)
 - Freespace (RootFS) : 1,6G
 - Freespace (userdata) : 1,6G
 - MOTD : DietPi Beta v7.6 is up for testing:
          https://github.com/MichaIng/DietPi/issues/4728
 DietPi Team     : MichaIng (lead), Daniel Knight (founder), Joulinar (support)
 Image by        : DietPi Core Team (pre-image: Raspbian Lite)
 Web             : https://dietpi.com | https://twitter.com/DietPi_
 Patreon Legends : Camry2731
 Contribute      : https://dietpi.com/contribute.html
 DietPi Hosting  : Powered by https://myvirtualserver.com
 dietpi-config   : Feature rich configuration tool for your device
 htop            : Resource monitor
 cpu             : Shows CPU information and stats
Now still the Baikal calendar to run again . . .
successfully:
Dashboard
About this system
Version
This systems runs Baïkal 0.8.0
http://sabre.io/baikal
Services
Web admin	On
CalDAV	On
CardDAV	On
License and credits
Baïkal is open source software licensed under the terms of the GNU GPL v3.
Baïkal is based upon other open source projects.
Read the README.md file to learn about that.
Baïkal was created by Jérôme Schneider
and is now developed by volunteers on GitHub.
Statistics
Users
Registered users	2
CalDAV
Number of calendars	4
Number of events	168
CardDAV
Number of address books	0
Number of contacts	0
Now I testing eth0 . . .
root@DietPi:~# sudo ifup eth0
Internet Systems Consortium DHCP Client 4.4.1
Copyright 2004-2018 Internet Systems Consortium.
All rights reserved.
For info, please visit https://www.isc.org/software/dhcp/
Cannot find device "eth0"
Failed to get interface index: No such device
If you think you have received this message due to a bug rather
than a configuration issue please read the section on submitting
bugs on either our web page at www.isc.org or in the README file
before submitting a bug.  These pages explain the proper
process and the information we find helpful for debugging.
exiting.
ifup: failed to bring up eth0
There cannot be a hardware error, because eth0 works with a DietPi installation on another SD card.
So this is on Bullseye now, right? WiFi works but the Ethernet adapter is not detected at all. Can you share:
ip l
ip a
ip r
dmesg
Good to have the full kernel log to see whether there was some attempt to load the Ethernet driver, or some failure about it. This is not about the userspace tools btw, but kernel related. Strange only that it works with the very same kernel on a fresh Bullseye image and for most others (only report with broken Ethernet?) with an upgraded image as well.
here are the requested data:
root@DietPi:~# ip l
1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN mode DEFAULT group default qlen 1000
2: enxb827ebcd0ec9: <BROADCAST,MULTICAST> mtu 1500 qdisc noop state DOWN mode DEFAULT group default qlen 1000
    link/ether b8:27:eb:cd:0e:c9 brd ff:ff:ff:ff:ff:ff
3: wlan0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc pfifo_fast state UP mode DORMANT group default qlen 1000
    link/ether b8:27:eb:98:5b:9c brd ff:ff:ff:ff:ff:ff
4: tun0: <POINTOPOINT,MULTICAST,NOARP,UP,LOWER_UP> mtu 1500 qdisc pfifo_fast state UNKNOWN mode DEFAULT group default qlen 500
    link/none
5: wg0: <POINTOPOINT,NOARP,UP,LOWER_UP> mtu 1420 qdisc noqueue state UNKNOWN mode DEFAULT group default qlen 1000
    link/none
root@DietPi:~# ip a
    inet6 ::1/128 scope host
2: enxb827ebcd0ec9: <BROADCAST,MULTICAST> mtu 1500 qdisc noop state DOWN group default qlen 1000
3: wlan0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc pfifo_fast state UP group default qlen 1000
    inet 192.168.115.143/24 brd 192.168.115.255 scope global dynamic wlan0
       valid_lft 863846sec preferred_lft 863846sec
    inet6 fd00::ba27:ebff:fe98:5b9c/64 scope global dynamic mngtmpaddr
       valid_lft 7045sec preferred_lft 3445sec
    inet6 2001:16b8:55ec:3d00:ba27:ebff:fe98:5b9c/64 scope global dynamic mngtmpaddr
    inet6 fe80::ba27:ebff:fe98:5b9c/64 scope link
4: tun0: <POINTOPOINT,MULTICAST,NOARP,UP,LOWER_UP> mtu 1500 qdisc pfifo_fast state UNKNOWN group default qlen 500
    link/none
    inet 10.8.0.1/24 scope global tun0
    inet6 fe80::c066:847:ede4:4d8a/64 scope link stable-privacy
5: wg0: <POINTOPOINT,NOARP,UP,LOWER_UP> mtu 1420 qdisc noqueue state UNKNOWN group default qlen 1000
    link/none
    inet 10.9.0.1/24 scope global wg0
root@DietPi:~# ip r
default via 192.168.115.5 dev wlan0
10.8.0.0/24 dev tun0 proto kernel scope link src 10.8.0.1
10.9.0.0/24 dev wg0 proto kernel scope link src 10.9.0.1
192.168.115.0/24 dev wlan0 proto kernel scope link src 192.168.115.143
root@DietPi:~# dmesg
[    0.000000] Booting Linux on physical CPU 0x0
[    0.000000] Linux version 5.10.60-v7+ (dom@buildbot) (arm-linux-gnueabihf-gcc-8 (Ubuntu/Linaro 8.4.0-3ubuntu1) 8.4.0, GNU ld (GNU Binutils for Ubuntu) 2.34) #1449 SMP Wed Aug 25 15:00:01 BST 2021
[    0.000000] CPU: ARMv7 Processor [410fd034] revision 4 (ARMv7), cr=10c5383d
[    0.000000] CPU: div instructions available: patching division code
[    0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
[    0.000000] OF: fdt: Machine model: Raspberry Pi 3 Model B Rev 1.2
[    0.000000] random: fast init done
[    0.000000] Memory policy: Data cache writealloc
[    0.000000] Reserved memory: created CMA memory pool at 0x37400000, size 64 MiB
[    0.000000] OF: reserved mem: initialized node linux,cma, compatible id shared-dma-pool
[    0.000000] Zone ranges:
[    0.000000]   DMA      [mem 0x0000000000000000-0x000000003b3fffff]
[    0.000000]   Normal   empty
[    0.000000] Movable zone start for each node
[    0.000000] Early memory node ranges
[    0.000000]   node   0: [mem 0x0000000000000000-0x000000003b3fffff]
[    0.000000] Initmem setup node 0 [mem 0x0000000000000000-0x000000003b3fffff]
[    0.000000] On node 0 totalpages: 242688
[    0.000000]   DMA zone: 2133 pages used for memmap
[    0.000000]   DMA zone: 0 pages reserved
[    0.000000]   DMA zone: 242688 pages, LIFO batch:63
[    0.000000] percpu: Embedded 20 pages/cpu s50700 r8192 d23028 u81920
[    0.000000] pcpu-alloc: s50700 r8192 d23028 u81920 alloc=20*4096
[    0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
[    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 240555
[    0.000000] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1 bcm2708_fb.fbwidth=1280 bcm2708_fb.fbheight=1024 bcm2708_fb.fbswap=1 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  dwc_otg.lpm_enable=0 console=tty1 root=PARTUUID=cb7b86f7-02 rootfstype=ext4 fsck.repair=yes rootwait
[    0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes, linear)
[    0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes, linear)
[    0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off
[    0.000000] Memory: 878804K/970752K available (10240K kernel code, 1312K rwdata, 2948K rodata, 1024K init, 863K bss, 26412K reserved, 65536K cma-reserved)
[    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
[    0.000000] ftrace: allocating 32048 entries in 63 pages
[    0.000000] ftrace: allocated 63 pages with 6 groups
[    0.000000] rcu: Hierarchical RCU implementation.
[    0.000000]  Rude variant of Tasks RCU enabled.
[    0.000000]  Tracing variant of Tasks RCU enabled.
[    0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 10 jiffies.
[    0.000000] NR_IRQS: 16, nr_irqs: 16, preallocated irqs: 16
[    0.000000] random: get_random_bytes called from start_kernel+0x3ac/0x580 with crng_init=1
[    0.000000] arch_timer: cp15 timer(s) running at 19.20MHz (phys).
[    0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x46d987e47, max_idle_ns: 440795202767 ns
[    0.000007] sched_clock: 56 bits at 19MHz, resolution 52ns, wraps every 4398046511078ns
[    0.000024] Switching to timer-based delay loop, resolution 52ns
[    0.000318] Console: colour dummy device 80x30
[    0.001142] printk: console [tty1] enabled
[    0.001211] Calibrating delay loop (skipped), value calculated using timer frequency.. 38.40 BogoMIPS (lpj=192000)
[    0.001269] pid_max: default: 32768 minimum: 301
[    0.001495] LSM: Security Framework initializing
[    0.001755] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes, linear)
[    0.001805] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes, linear)
[    0.003277] cgroup: Disabling memory control group subsystem
[    0.003562] CPU: Testing write buffer coherency: ok
[    0.004084] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
[    0.005354] Setting up static identity map for 0x100000 - 0x10003c
[    0.005565] rcu: Hierarchical SRCU implementation.
[    0.006520] smp: Bringing up secondary CPUs ...
[    0.007707] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
[    0.008999] CPU2: thread -1, cpu 2, socket 0, mpidr 80000002
[    0.010347] CPU3: thread -1, cpu 3, socket 0, mpidr 80000003
[    0.010505] smp: Brought up 1 node, 4 CPUs
[    0.010559] SMP: Total of 4 processors activated (153.60 BogoMIPS).
[    0.010590] CPU: All CPU(s) started in HYP mode.
[    0.010617] CPU: Virtualization extensions available.
[    0.011639] devtmpfs: initialized
[    0.029043] VFP support v0.3: implementor 41 architecture 3 part 40 variant 3 rev 4
[    0.029367] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[    0.029429] futex hash table entries: 1024 (order: 4, 65536 bytes, linear)
[    0.032671] pinctrl core: initialized pinctrl subsystem
[    0.033876] NET: Registered protocol family 16
[    0.038116] DMA: preallocated 1024 KiB pool for atomic coherent allocations
[    0.043817] audit: initializing netlink subsys (disabled)
[    0.044716] thermal_sys: Registered thermal governor 'step_wise'
[    0.045566] audit: type=2000 audit(0.040:1): state=initialized audit_enabled=0 res=1
[    0.045795] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
[    0.045835] hw-breakpoint: maximum watchpoint size is 8 bytes.
[    0.046153] Serial: AMBA PL011 UART driver
[    0.064324] bcm2835-mbox 3f00b880.mailbox: mailbox enabled
[    0.080147] raspberrypi-firmware soc:firmware: Attached to firmware from 2021-08-31T14:55:00, variant start
[    0.090157] raspberrypi-firmware soc:firmware: Firmware hash is 67615e950e1e28b92dfae6303cf7a8b879a8908f
[    0.134256] Kprobes globally optimized
[    0.139307] bcm2835-dma 3f007000.dma: DMA legacy API manager, dmachans=0x1
[    0.141707] SCSI subsystem initialized
[    0.141989] usbcore: registered new interface driver usbfs
[    0.142074] usbcore: registered new interface driver hub
[    0.142162] usbcore: registered new device driver usb
[    0.144170] clocksource: Switched to clocksource arch_sys_counter
[    1.916922] VFS: Disk quotas dquot_6.6.0
[    1.917074] VFS: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[    1.917302] FS-Cache: Loaded
[    1.917553] CacheFiles: Loaded
[    1.928033] NET: Registered protocol family 2
[    1.928333] IP idents hash table entries: 16384 (order: 5, 131072 bytes, linear)
[    1.929776] tcp_listen_portaddr_hash hash table entries: 512 (order: 0, 6144 bytes, linear)
[    1.929961] TCP established hash table entries: 8192 (order: 3, 32768 bytes, linear)
[    1.930107] TCP bind hash table entries: 8192 (order: 4, 65536 bytes, linear)
[    1.930320] TCP: Hash tables configured (established 8192 bind 8192)
[    1.930518] UDP hash table entries: 512 (order: 2, 16384 bytes, linear)
[    1.930596] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes, linear)
[    1.931303] NET: Registered protocol family 1
[    1.932101] RPC: Registered named UNIX socket transport module.
[    1.932137] RPC: Registered udp transport module.
[    1.932166] RPC: Registered tcp transport module.
[    1.932195] RPC: Registered tcp NFSv4.1 backchannel transport module.
[    1.933869] hw perfevents: enabled with armv7_cortex_a7 PMU driver, 7 counters available
[    1.937719] Initialise system trusted keyrings
[    1.938018] workingset: timestamp_bits=14 max_order=18 bucket_order=4
[    1.947613] zbud: loaded
[    1.949707] FS-Cache: Netfs 'nfs' registered for caching
[    1.950616] NFS: Registering the id_resolver key type
[    1.950700] Key type id_resolver registered
[    1.950730] Key type id_legacy registered
[    1.950902] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[    1.950938] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering...
[    1.952155] Key type asymmetric registered
[    1.952188] Asymmetric key parser 'x509' registered
[    1.952261] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 249)
[    1.952302] io scheduler mq-deadline registered
[    1.952331] io scheduler kyber registered
[    1.957623] bcm2708_fb soc:fb: FB found 1 display(s)
[    2.004709] Console: switching to colour frame buffer device 160x64
[    2.026289] bcm2708_fb soc:fb: Registered framebuffer for display 0, size 1280x1024
[    2.032201] bcm2835-rng 3f104000.rng: hwrng registered
[    2.032807] vc-mem: phys_addr:0x00000000 mem_base=0x3ec00000 mem_size:0x40000000(1024 MiB)
[    2.033909] gpiomem-bcm2835 3f200000.gpiomem: Initialised: Registers at 0x3f200000
[    2.046554] brd: module loaded
[    2.059050] loop: module loaded
[    2.060953] Loading iSCSI transport class v2.0-870.
[    2.062710] libphy: Fixed MDIO Bus: probed
[    2.063144] usbcore: registered new interface driver lan78xx
[    2.063374] usbcore: registered new interface driver smsc95xx
[    2.063565] dwc_otg: version 3.00a 10-AUG-2012 (platform bus)
[    2.791977] Core Release: 2.80a
[    2.792093] Setting default values for core params
[    2.792264] Finished setting default values for core params
[    2.992793] Using Buffer DMA mode
[    2.992910] Periodic Transfer Interrupt Enhancement - disabled
[    2.993087] Multiprocessor Interrupt Enhancement - disabled
[    2.993257] OTG VER PARAM: 0, OTG VER FLAG: 0
[    2.993410] Dedicated Tx FIFOs mode
[    2.994130] WARN::dwc_otg_hcd_init:1074: FIQ DMA bounce buffers: virt = b7504000 dma = 0xf7504000 len=9024
[    2.994509] FIQ FSM acceleration enabled for :
               Non-periodic Split Transactions
               Periodic Split Transactions
               High-Speed Isochronous Endpoints
               Interrupt/Control Split Transaction hack enabled
[    2.995111] dwc_otg: Microframe scheduler enabled
[    2.995188] WARN::hcd_init_fiq:457: FIQ on core 1
[    2.995390] WARN::hcd_init_fiq:458: FIQ ASM at 807c8db0 length 36
[    3.009595] WARN::hcd_init_fiq:497: MPHI regs_base at bb810000
[    3.023686] dwc_otg 3f980000.usb: DWC OTG Controller
[    3.030792] dwc_otg 3f980000.usb: new USB bus registered, assigned bus number 1
[    3.037985] dwc_otg 3f980000.usb: irq 89, io mem 0x00000000
[    3.045094] Init: Port Power? op_state=1
[    3.052137] Init: Power Port (0)
[    3.059584] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.10
[    3.066896] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    3.074137] usb usb1: Product: DWC OTG Controller
[    3.081282] usb usb1: Manufacturer: Linux 5.10.60-v7+ dwc_otg_hcd
[    3.088490] usb usb1: SerialNumber: 3f980000.usb
[    3.096418] hub 1-0:1.0: USB hub found
[    3.103515] hub 1-0:1.0: 1 port detected
[    3.112049] dwc_otg: FIQ enabled
[    3.112064] dwc_otg: NAK holdoff enabled
[    3.112075] dwc_otg: FIQ split-transaction FSM enabled
[    3.112093] Module dwc_common_port init
[    3.112396] usbcore: registered new interface driver usb-storage
[    3.119725] mousedev: PS/2 mouse device common for all mice
[    3.128242] bcm2835-wdt bcm2835-wdt: Broadcom BCM2835 watchdog timer
[    3.138057] sdhci: Secure Digital Host Controller Interface driver
[    3.145256] sdhci: Copyright(c) Pierre Ossman
[    3.152976] mmc-bcm2835 3f300000.mmcnr: could not get clk, deferring probe
[    3.160829] sdhost-bcm2835 3f202000.mmc: could not get clk, deferring probe
[    3.168268] sdhci-pltfm: SDHCI platform and OF driver helper
[    3.177350] ledtrig-cpu: registered to indicate activity on CPUs
[    3.185073] hid: raw HID events driver (C) Jiri Kosina
[    3.192394] usbcore: registered new interface driver usbhid
[    3.199566] usbhid: USB HID core driver
[    3.211695] Initializing XFRM netlink socket
[    3.218974] NET: Registered protocol family 17
[    3.226243] Key type dns_resolver registered
[    3.233882] Registering SWP/SWPB emulation handler
[    3.241088] Indeed it is in host mode hprt0 = 00021501
[    3.254406] registered taskstats version 1
[    3.261280] Loading compiled-in X.509 certificates
[    3.308637] Key type ._fscrypt registered
[    3.315520] Key type .fscrypt registered
[    3.322322] Key type fscrypt-provisioning registered
[    3.340869] uart-pl011 3f201000.serial: cts_event_workaround enabled
[    3.347923] 3f201000.serial: ttyAMA0 at MMIO 0x3f201000 (irq = 114, base_baud = 0) is a PL011 rev2
[    3.357442] bcm2835-power bcm2835-power: Broadcom BCM2835 power domains driver
[    3.366386] mmc-bcm2835 3f300000.mmcnr: mmc_debug:0 mmc_debug2:0
[    3.373529] mmc-bcm2835 3f300000.mmcnr: DMA channel allocated
[    3.407661] sdhost: log_buf @ (ptrval) (f7507000)
[    3.450738] mmc1: queuing unknown CIS tuple 0x80 (2 bytes)
[    3.454252] usb 1-1: new high-speed USB device number 2 using dwc_otg
[    3.459571] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
[    3.465151] Indeed it is in host mode hprt0 = 00001101
[    3.472173] mmc0: sdhost-bcm2835 loaded - DMA enabled (>1)
[    3.489506] of_cfs_init
[    3.496919] of_cfs_init: OK
[    3.505093] Waiting for root device PARTUUID=cb7b86f7-02...
[    3.507768] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
[    3.522090] mmc1: queuing unknown CIS tuple 0x80 (7 bytes)
[    3.589005] mmc0: host does not support reading read-only switch, assuming write-enable
[    3.600298] mmc0: new high speed SDHC card at address aaaa
[    3.608456] mmcblk0: mmc0:aaaa SL16G 14.8 GiB
[    3.619983]  mmcblk0: p1 p2
[    3.670757] mmc1: new high speed SDIO card at address 0001
[    3.671779] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
[    3.685415] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
[    3.701339] devtmpfs: mounted
[    3.714709] usb 1-1: New USB device found, idVendor=0424, idProduct=9514, bcdDevice= 2.00
[    3.715889] Freeing unused kernel memory: 1024K
[    3.722154] usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[    3.737459] Run /sbin/init as init process
[    3.738308] hub 1-1:1.0: USB hub found
[    3.744940]   with arguments:
[    3.744953]     /sbin/init
[    3.752343]   with environment:
[    3.752355]     HOME=/
[    3.752368]     TERM=linux
[    3.752467] hub 1-1:1.0: 5 ports detected
[    4.074236] usb 1-1.1: new high-speed USB device number 3 using dwc_otg
[    4.204666] usb 1-1.1: New USB device found, idVendor=0424, idProduct=ec00, bcdDevice= 2.00
[    4.212252] usb 1-1.1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[    4.222745] smsc95xx v2.0.0
[    4.439945] systemd[1]: System time before build time, advancing clock.
[    4.473236] libphy: smsc95xx-mdiobus: probed
[    4.481933] smsc95xx 1-1.1:1.0 eth0: register 'smsc95xx' at usb-3f980000.usb-1.1, smsc95xx USB 2.0 Ethernet, b8:27:eb:cd:0e:c9
[    4.559798] NET: Registered protocol family 10
[    4.569365] Segment Routing with IPv6
[    4.584246] usb 1-1.4: new full-speed USB device number 4 using dwc_otg
[    4.647985] systemd[1]: systemd 247.3-6+rpi1 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +ZSTD +SECCOMP +BLKID +ELFUTILS +KMOD +IDN2 -IDN +PCRE2 default-hierarchy=unified)
[    4.665906] systemd[1]: Detected architecture arm.
[    4.712646] systemd[1]: Set hostname to <DietPi>.
[    4.723258] usb 1-1.4: New USB device found, idVendor=046d, idProduct=c52b, bcdDevice=12.01
[    4.744528] usb 1-1.4: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[    4.752959] usb 1-1.4: Product: USB Receiver
[    4.752974] usb 1-1.4: Manufacturer: Logitech
[    4.777525] input: Logitech USB Receiver as /devices/platform/soc/3f980000.usb/usb1/1-1/1-1.4/1-1.4:1.0/0003:046D:C52B.0001/input/input0
[    4.859441] hid-generic 0003:046D:C52B.0001: input,hidraw0: USB HID v1.11 Keyboard [Logitech USB Receiver] on usb-3f980000.usb-1.4/input0
[    4.891308] input: Logitech USB Receiver Mouse as /devices/platform/soc/3f980000.usb/usb1/1-1/1-1.4/1-1.4:1.1/0003:046D:C52B.0002/input/input1
[    4.904951] input: Logitech USB Receiver Consumer Control as /devices/platform/soc/3f980000.usb/usb1/1-1/1-1.4/1-1.4:1.1/0003:046D:C52B.0002/input/input2
[    4.984779] input: Logitech USB Receiver System Control as /devices/platform/soc/3f980000.usb/usb1/1-1/1-1.4/1-1.4:1.1/0003:046D:C52B.0002/input/input3
[    5.004796] hid-generic 0003:046D:C52B.0002: input,hiddev96,hidraw1: USB HID v1.11 Mouse [Logitech USB Receiver] on usb-3f980000.usb-1.4/input1
[    5.021521] hid-generic 0003:046D:C52B.0003: hiddev97,hidraw2: USB HID v1.11 Device [Logitech USB Receiver] on usb-3f980000.usb-1.4/input2
[    6.050199] systemd[1]: Queued start job for default target Graphical Interface.
[    6.062666] random: systemd: uninitialized urandom read (16 bytes read)
[    6.075295] systemd[1]: Created slice system-getty.slice.
[    6.096356] random: systemd: uninitialized urandom read (16 bytes read)
[    6.107456] systemd[1]: Created slice system-modprobe.slice.
[    6.128298] random: systemd: uninitialized urandom read (16 bytes read)
[    6.139407] systemd[1]: Created slice system-openvpn.slice.
[    6.161674] systemd[1]: Created slice system-systemd\x2dfsck.slice.
[    6.184211] systemd[1]: Created slice system-wg\x2dquick.slice.
[    6.206607] systemd[1]: Created slice User and Session Slice.
[    6.228582] systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
[    6.250729] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[    6.273930] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
[    6.297026] systemd[1]: Reached target Local Encrypted Volumes.
[    6.320161] systemd[1]: Reached target Host and Network Name Lookups.
[    6.342639] systemd[1]: Reached target Paths.
[    6.364911] systemd[1]: Reached target Remote File Systems.
[    6.387296] systemd[1]: Reached target Slices.
[    6.418261] systemd[1]: Listening on Syslog Socket.
[    6.441406] systemd[1]: Listening on fsck to fsckd communication Socket.
[    6.464335] systemd[1]: Listening on initctl Compatibility Named Pipe.
[    6.487884] systemd[1]: Listening on Journal Audit Socket.
[    6.510817] systemd[1]: Listening on Journal Socket (/dev/log).
[    6.533383] systemd[1]: Listening on Journal Socket.
[    6.555768] systemd[1]: Listening on udev Control Socket.
[    6.577911] systemd[1]: Listening on udev Kernel Socket.
[    6.600463] systemd[1]: Condition check resulted in Huge Pages File System being skipped.
[    6.615802] systemd[1]: Mounting POSIX Message Queue File System...
[    6.644792] systemd[1]: Mounting Kernel Debug File System...
[    6.672255] systemd[1]: Mounting Kernel Trace File System...
[    6.702087] systemd[1]: Starting Restore / save the current clock...
[    6.729874] systemd[1]: Starting Set the console keyboard layout...
[    6.758197] systemd[1]: Starting Create list of static device nodes for the current kernel...
[    6.787001] systemd[1]: Starting Load Kernel Module configfs...
[    6.818372] systemd[1]: Starting Load Kernel Module drm...
[    6.848542] systemd[1]: Starting Load Kernel Module fuse...
[    6.877833] systemd[1]: Started Nameserver information manager.
[    6.932745] systemd[1]: Condition check resulted in Set Up Additional Binary Formats being skipped.
[    6.949683] systemd[1]: Starting File System Check on Root Device...
[    6.983895] fuse: init (API version 7.32)
[    7.001946] systemd[1]: Starting Journal Service...
[    7.033192] systemd[1]: Starting Load Kernel Modules...
[    7.061921] systemd[1]: Starting Coldplug All udev Devices...
[    7.111941] systemd[1]: Mounted POSIX Message Queue File System.
[    7.133749] systemd[1]: Mounted Kernel Debug File System.
[    7.154894] systemd[1]: Mounted Kernel Trace File System.
[    7.177907] systemd[1]: Finished Restore / save the current clock.
[    7.200511] systemd[1]: Finished Create list of static device nodes for the current kernel.
[    7.223326] systemd[1]: modprobe@configfs.service: Succeeded.
[    7.234659] systemd[1]: Finished Load Kernel Module configfs.
[    7.257459] systemd[1]: modprobe@drm.service: Succeeded.
[    7.268855] systemd[1]: Finished Load Kernel Module drm.
[    7.292032] systemd[1]: modprobe@fuse.service: Succeeded.
[    7.303084] systemd[1]: Finished Load Kernel Module fuse.
[    7.328254] systemd[1]: Finished Load Kernel Modules.
[    7.348451] systemd[1]: Started Journal Service.
[    7.694743] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
[    7.814311] Adding 1098748k swap on /var/swap.  Priority:-2 extents:8 across:1246204k SSFS
[    8.126839] systemd-journald[141]: Received client request to flush runtime journal.
[    8.493316] vc_sm_cma: module is from the staging directory, the quality is unknown, you have been warned.
[    8.496527] bcm2835_vc_sm_cma_probe: Videocore shared memory driver
[    8.496556] [vc_sm_connected_init]: start
[    8.504864] [vc_sm_connected_init]: installed successfully
[    8.774016] smsc95xx 1-1.1:1.0 enxb827ebcd0ec9: renamed from eth0
[    8.839278] cfg80211: Loading compiled-in X.509 certificates for regulatory database
[    8.974038] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
[    8.987591] cfg80211: loaded regulatory.db is malformed or signature is missing/invalid
[    9.090550] brcmfmac: F1 signature read @0x18000000=0x1541a9a6
[    9.127107] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43430-sdio for chip BCM43430/1
[    9.131192] usbcore: registered new interface driver brcmfmac
[    9.361387] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43430-sdio for chip BCM43430/1
[    9.361568] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43430-sdio for chip BCM43430/1
[    9.361655] brcmfmac: brcmf_c_process_clm_blob: no clm_blob available (err=-2), device may have limited channels available
[    9.362548] brcmfmac: brcmf_c_preinit_dcmds: Firmware: BCM43430/1 wl0: Oct 22 2019 01:59:28 version 7.45.98.94 (r723000 CY) FWID 01-3b33decd
[    9.403679] logitech-djreceiver 0003:046D:C52B.0003: hiddev96,hidraw0: USB HID v1.11 Device [Logitech USB Receiver] on usb-3f980000.usb-1.4/input2
[    9.489773] random: crng init done
[    9.489796] random: 7 urandom warning(s) missed due to ratelimiting
[    9.543289] input: Logitech Wireless Device PID:400e Keyboard as /devices/platform/soc/3f980000.usb/usb1/1-1/1-1.4/1-1.4:1.2/0003:046D:C52B.0003/0003:046D:400E.0004/input/input5
[    9.548343] input: Logitech Wireless Device PID:400e Mouse as /devices/platform/soc/3f980000.usb/usb1/1-1/1-1.4/1-1.4:1.2/0003:046D:C52B.0003/0003:046D:400E.0004/input/input6
[    9.549683] input: Logitech Wireless Device PID:400e Consumer Control as /devices/platform/soc/3f980000.usb/usb1/1-1/1-1.4/1-1.4:1.2/0003:046D:C52B.0003/0003:046D:400E.0004/input/input7
[    9.550229] hid-generic 0003:046D:400E.0004: input,hidraw1: USB HID v1.11 Keyboard [Logitech Wireless Device PID:400e] on usb-3f980000.usb-1.4/input2:1
[   10.254930] input: Logitech K400 as /devices/platform/soc/3f980000.usb/usb1/1-1/1-1.4/1-1.4:1.2/0003:046D:C52B.0003/0003:046D:400E.0004/input/input11
[   10.256378] logitech-hidpp-device 0003:046D:400E.0004: input,hidraw1: USB HID v1.11 Keyboard [Logitech K400] on usb-3f980000.usb-1.4/input2:1
[   12.309937] brcmfmac: brcmf_cfg80211_set_power_mgmt: power save enabled
[   13.816392] IPv6: ADDRCONF(NETDEV_CHANGE): wlan0: link becomes ready
[   16.986344] FS-Cache: Netfs 'cifs' registered for caching
[   17.020465] Key type cifs.spnego registered
[   17.020502] Key type cifs.idmap registered
[   17.022474] CIFS: Attempting to mount //192.168.115.5/FB-7590-Router/USBDISK3-0-01/Musik
[   17.023239] CIFS: Attempting to mount //192.168.115.130/FRITZ.NAS/HDD_250_GB/Musik
[   17.025746] CIFS: Attempting to mount //192.168.115.130/FRITZ.NAS/NAS_7490/Musik
[   17.026133] CIFS: Attempting to mount //192.168.115.111/usbshare2/Musik
[   17.042719] FS-Cache: Duplicate cookie detected
[   17.042746] FS-Cache: O-cookie c=b670f09e [p=28c4494d fl=222 nc=0 na=1]
[   17.042753] FS-Cache: O-cookie d=6547549f n=18eaee3b
[   17.042760] FS-Cache: O-key=[8] '020001bdc0a87382'
[   17.042827] FS-Cache: N-cookie c=c5963b75 [p=28c4494d fl=2 nc=0 na=1]
[   17.042833] FS-Cache: N-cookie d=6547549f n=4e2eb2e7
[   17.042838] FS-Cache: N-key=[8] '020001bdc0a87382'
[   17.334891] CIFS: Status code returned 0xc000006d STATUS_LOGON_FAILURE
[   17.334945] CIFS: VFS: \\192.168.115.5 Send error in SessSetup = -13
[   17.335004] CIFS: VFS: cifs_mount failed w/return code = -13
[   17.348892] tun: Universal TUN/TAP device driver, 1.6
[   17.911660] wireguard: WireGuard 1.0.0 loaded. See www.wireguard.com for information.
[   17.911676] wireguard: Copyright (C) 2015-2019 Jason A. Donenfeld <Jason@zx2c4.com>. All Rights Reserved.
[   23.274513] CIFS: VFS: Error connecting to socket. Aborting operation.
[   23.274547] CIFS: VFS: cifs_mount failed w/return code = -113
Many thanks and greetings.
another output:
root@DietPi:~# journalctl -k
Journal file /var/log/journal/ba438a1b05f24dfdaccc92d1ac56fe95/system.journal is truncated, ignoring file.
-- Journal begins at Sat 2021-09-18 11:50:17 CEST, ends at Sat 2021-09-18 18:19:21 CEST. --
Sep 18 11:50:17 DietPi kernel: Booting Linux on physical CPU 0x0
Sep 18 11:50:17 DietPi kernel: Linux version 5.10.60-v7+ (dom@buildbot) (arm-linux-gnueabihf-gcc-8 (Ubuntu/Linaro 8.4.0-3ubuntu1) 8.4.0, GNU ld (GNU Binutils for Ubuntu) 2.34) #1449 SMP Wed Aug 25 15:00:01 BST 2021
Sep 18 11:50:17 DietPi kernel: CPU: ARMv7 Processor [410fd034] revision 4 (ARMv7), cr=10c5383d
Sep 18 11:50:17 DietPi kernel: CPU: div instructions available: patching division code
Sep 18 11:50:17 DietPi kernel: CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
Sep 18 11:50:17 DietPi kernel: OF: fdt: Machine model: Raspberry Pi 3 Model B Rev 1.2
Sep 18 11:50:17 DietPi kernel: random: fast init done
Sep 18 11:50:17 DietPi kernel: Memory policy: Data cache writealloc
Sep 18 11:50:17 DietPi kernel: Reserved memory: created CMA memory pool at 0x37400000, size 64 MiB
Sep 18 11:50:17 DietPi kernel: OF: reserved mem: initialized node linux,cma, compatible id shared-dma-pool
Sep 18 11:50:17 DietPi kernel: Zone ranges:
Sep 18 11:50:17 DietPi kernel:   DMA      [mem 0x0000000000000000-0x000000003b3fffff]
Sep 18 11:50:17 DietPi kernel:   Normal   empty
Sep 18 11:50:17 DietPi kernel: Movable zone start for each node
Sep 18 11:50:17 DietPi kernel: Early memory node ranges
Sep 18 11:50:17 DietPi kernel:   node   0: [mem 0x0000000000000000-0x000000003b3fffff]
Sep 18 11:50:17 DietPi kernel: Initmem setup node 0 [mem 0x0000000000000000-0x000000003b3fffff]
Sep 18 11:50:17 DietPi kernel: On node 0 totalpages: 242688
Sep 18 11:50:17 DietPi kernel:   DMA zone: 2133 pages used for memmap
Sep 18 11:50:17 DietPi kernel:   DMA zone: 0 pages reserved
Sep 18 11:50:17 DietPi kernel:   DMA zone: 242688 pages, LIFO batch:63
Sep 18 11:50:17 DietPi kernel: percpu: Embedded 20 pages/cpu s50700 r8192 d23028 u81920
Sep 18 11:50:17 DietPi kernel: pcpu-alloc: s50700 r8192 d23028 u81920 alloc=20*4096
Sep 18 11:50:17 DietPi kernel: pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
Sep 18 11:50:17 DietPi kernel: Built 1 zonelists, mobility grouping on.  Total pages: 240555
Sep 18 11:50:17 DietPi kernel: Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1 bcm2708_fb.fbwidth=1280 bcm2708_fb.fbheight=1024 bcm2708_fb.fbswap=1 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  dwc_otg.lpm_enable=0 console=tty1 root=PARTUUID=cb7b86f7-02 rootfstype=ext4 fsck.repair=yes rootwait
Sep 18 11:50:17 DietPi kernel: Dentry cache hash table entries: 131072 (order: 7, 524288 bytes, linear)
Sep 18 11:50:17 DietPi kernel: Inode-cache hash table entries: 65536 (order: 6, 262144 bytes, linear)
Sep 18 11:50:17 DietPi kernel: mem auto-init: stack:off, heap alloc:off, heap free:off
Sep 18 11:50:17 DietPi kernel: Memory: 878804K/970752K available (10240K kernel code, 1312K rwdata, 2948K rodata, 1024K init, 863K bss, 26412K reserved, 65536K cma-reserved)
Sep 18 11:50:17 DietPi kernel: SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
Sep 18 11:50:17 DietPi kernel: ftrace: allocating 32048 entries in 63 pages
Sep 18 11:50:17 DietPi kernel: ftrace: allocated 63 pages with 6 groups
Sep 18 11:50:17 DietPi kernel: rcu: Hierarchical RCU implementation.
Sep 18 11:50:17 DietPi kernel:         Rude variant of Tasks RCU enabled.
Sep 18 11:50:17 DietPi kernel:         Tracing variant of Tasks RCU enabled.
Sep 18 11:50:17 DietPi kernel: rcu: RCU calculated value of scheduler-enlistment delay is 10 jiffies.
Sep 18 11:50:17 DietPi kernel: NR_IRQS: 16, nr_irqs: 16, preallocated irqs: 16
Sep 18 11:50:17 DietPi kernel: random: get_random_bytes called from start_kernel+0x3ac/0x580 with crng_init=1
Sep 18 11:50:17 DietPi kernel: arch_timer: cp15 timer(s) running at 19.20MHz (phys).
Sep 18 11:50:17 DietPi kernel: clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x46d987e47, max_idle_ns: 440795202767 ns
Sep 18 11:50:17 DietPi kernel: sched_clock: 56 bits at 19MHz, resolution 52ns, wraps every 4398046511078ns
Sep 18 11:50:17 DietPi kernel: Switching to timer-based delay loop, resolution 52ns
Sep 18 11:50:17 DietPi kernel: Console: colour dummy device 80x30
Sep 18 11:50:17 DietPi kernel: printk: console [tty1] enabled
Sep 18 11:50:17 DietPi kernel: Calibrating delay loop (skipped), value calculated using timer frequency.. 38.40 BogoMIPS (lpj=192000)
Sep 18 11:50:17 DietPi kernel: pid_max: default: 32768 minimum: 301
Sep 18 11:50:17 DietPi kernel: LSM: Security Framework initializing
Sep 18 11:50:17 DietPi kernel: Mount-cache hash table entries: 2048 (order: 1, 8192 bytes, linear)
Sep 18 11:50:17 DietPi kernel: Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes, linear)
Sep 18 11:50:17 DietPi kernel: cgroup: Disabling memory control group subsystem
Sep 18 11:50:17 DietPi kernel: CPU: Testing write buffer coherency: ok
Sep 18 11:50:17 DietPi kernel: CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
Sep 18 11:50:17 DietPi kernel: Setting up static identity map for 0x100000 - 0x10003c
Sep 18 11:50:17 DietPi kernel: rcu: Hierarchical SRCU implementation.
Sep 18 11:50:17 DietPi kernel: smp: Bringing up secondary CPUs ...
Sep 18 11:50:17 DietPi kernel: CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
Sep 18 11:50:17 DietPi kernel: CPU2: thread -1, cpu 2, socket 0, mpidr 80000002
Sep 18 11:50:17 DietPi kernel: CPU3: thread -1, cpu 3, socket 0, mpidr 80000003
Sep 18 11:50:17 DietPi kernel: smp: Brought up 1 node, 4 CPUs
Sep 18 11:50:17 DietPi kernel: SMP: Total of 4 processors activated (153.60 BogoMIPS).
Sep 18 11:50:17 DietPi kernel: CPU: All CPU(s) started in HYP mode.
Sep 18 11:50:17 DietPi kernel: CPU: Virtualization extensions available.
Sep 18 11:50:17 DietPi kernel: devtmpfs: initialized
Sep 18 11:50:17 DietPi kernel: VFP support v0.3: implementor 41 architecture 3 part 40 variant 3 rev 4
Sep 18 11:50:17 DietPi kernel: clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
Sep 18 11:50:17 DietPi kernel: futex hash table entries: 1024 (order: 4, 65536 bytes, linear)
Sep 18 11:50:17 DietPi kernel: pinctrl core: initialized pinctrl subsystem
Sep 18 11:50:17 DietPi kernel: NET: Registered protocol family 16
Sep 18 11:50:17 DietPi kernel: DMA: preallocated 1024 KiB pool for atomic coherent allocations
Sep 18 11:50:17 DietPi kernel: audit: initializing netlink subsys (disabled)
Sep 18 11:50:17 DietPi kernel: thermal_sys: Registered thermal governor 'step_wise'
Sep 18 11:50:17 DietPi kernel: audit: type=2000 audit(0.040:1): state=initialized audit_enabled=0 res=1
Sep 18 11:50:17 DietPi kernel: hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
Sep 18 11:50:17 DietPi kernel: hw-breakpoint: maximum watchpoint size is 8 bytes.
Sep 18 11:50:17 DietPi kernel: Serial: AMBA PL011 UART driver
Sep 18 11:50:17 DietPi kernel: bcm2835-mbox 3f00b880.mailbox: mailbox enabled
Sep 18 11:50:17 DietPi kernel: raspberrypi-firmware soc:firmware: Attached to firmware from 2021-08-31T14:55:00, variant start
Sep 18 11:50:17 DietPi kernel: raspberrypi-firmware soc:firmware: Firmware hash is 67615e950e1e28b92dfae6303cf7a8b879a8908f
Sep 18 11:50:17 DietPi kernel: Kprobes globally optimized
Sep 18 11:50:17 DietPi kernel: bcm2835-dma 3f007000.dma: DMA legacy API manager, dmachans=0x1
Sep 18 11:50:17 DietPi kernel: SCSI subsystem initialized
Sep 18 11:50:17 DietPi kernel: usbcore: registered new interface driver usbfs
Sep 18 11:50:17 DietPi kernel: usbcore: registered new interface driver hub
Sep 18 11:50:17 DietPi kernel: usbcore: registered new device driver usb
Sep 18 11:50:17 DietPi kernel: clocksource: Switched to clocksource arch_sys_counter
Sep 18 11:50:17 DietPi kernel: VFS: Disk quotas dquot_6.6.0
Sep 18 11:50:17 DietPi kernel: VFS: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
Sep 18 11:50:17 DietPi kernel: FS-Cache: Loaded
Sep 18 11:50:17 DietPi kernel: CacheFiles: Loaded
Sep 18 11:50:17 DietPi kernel: NET: Registered protocol family 2
Sep 18 11:50:17 DietPi kernel: IP idents hash table entries: 16384 (order: 5, 131072 bytes, linear)
Sep 18 11:50:17 DietPi kernel: tcp_listen_portaddr_hash hash table entries: 512 (order: 0, 6144 bytes, linear)
Sep 18 11:50:17 DietPi kernel: TCP established hash table entries: 8192 (order: 3, 32768 bytes, linear)
Sep 18 11:50:17 DietPi kernel: TCP bind hash table entries: 8192 (order: 4, 65536 bytes, linear)
Sep 18 11:50:17 DietPi kernel: TCP: Hash tables configured (established 8192 bind 8192)
Sep 18 11:50:17 DietPi kernel: UDP hash table entries: 512 (order: 2, 16384 bytes, linear)
Sep 18 11:50:17 DietPi kernel: UDP-Lite hash table entries: 512 (order: 2, 16384 bytes, linear)
Sep 18 11:50:17 DietPi kernel: RPC: Registered named UNIX socket transport module.
Sep 18 11:50:17 DietPi kernel: RPC: Registered udp transport module.
Sep 18 11:50:17 DietPi kernel: RPC: Registered tcp transport module.
Sep 18 11:50:17 DietPi kernel: RPC: Registered tcp NFSv4.1 backchannel transport module.
Sep 18 11:50:17 DietPi kernel: hw perfevents: enabled with armv7_cortex_a7 PMU driver, 7 counters available
Sep 18 11:50:17 DietPi kernel: Initialise system trusted keyrings
Sep 18 11:50:17 DietPi kernel: workingset: timestamp_bits=14 max_order=18 bucket_order=4
Sep 18 11:50:17 DietPi kernel: zbud: loaded
Sep 18 11:50:17 DietPi kernel: FS-Cache: Netfs 'nfs' registered for caching
Sep 18 11:50:17 DietPi kernel: NFS: Registering the id_resolver key type
Sep 18 11:50:17 DietPi kernel: Key type id_resolver registered
Sep 18 11:50:17 DietPi kernel: Key type id_legacy registered
Sep 18 11:50:17 DietPi kernel: nfs4filelayout_init: NFSv4 File Layout Driver Registering...
Sep 18 11:50:17 DietPi kernel: nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering...
Sep 18 11:50:17 DietPi kernel: Key type asymmetric registered
Sep 18 11:50:17 DietPi kernel: Asymmetric key parser 'x509' registered
Sep 18 11:50:17 DietPi kernel: Block layer SCSI generic (bsg) driver version 0.4 loaded (major 249)
Sep 18 11:50:17 DietPi kernel: io scheduler mq-deadline registered
Sep 18 11:50:17 DietPi kernel: io scheduler kyber registered
Sep 18 11:50:17 DietPi kernel: bcm2708_fb soc:fb: FB found 1 display(s)
Sep 18 11:50:17 DietPi kernel: Console: switching to colour frame buffer device 160x64
Sep 18 11:50:17 DietPi kernel: bcm2708_fb soc:fb: Registered framebuffer for display 0, size 1280x1024
Sep 18 11:50:17 DietPi kernel: bcm2835-rng 3f104000.rng: hwrng registered
Sep 18 11:50:17 DietPi kernel: vc-mem: phys_addr:0x00000000 mem_base=0x3ec00000 mem_size:0x40000000(1024 MiB)
Sep 18 11:50:17 DietPi kernel: gpiomem-bcm2835 3f200000.gpiomem: Initialised: Registers at 0x3f200000
Sep 18 11:50:17 DietPi kernel: brd: module loaded
Sep 18 11:50:17 DietPi kernel: loop: module loaded
Sep 18 11:50:17 DietPi kernel: Loading iSCSI transport class v2.0-870.
Sep 18 11:50:17 DietPi kernel: libphy: Fixed MDIO Bus: probed
Sep 18 11:50:17 DietPi kernel: usbcore: registered new interface driver lan78xx
Sep 18 11:50:17 DietPi kernel: usbcore: registered new interface driver smsc95xx
Sep 18 11:50:17 DietPi kernel: dwc_otg: version 3.00a 10-AUG-2012 (platform bus)
Sep 18 11:50:17 DietPi kernel: Core Release: 2.80a
Sep 18 11:50:17 DietPi kernel: Setting default values for core params
Sep 18 11:50:17 DietPi kernel: Finished setting default values for core params
Sep 18 11:50:17 DietPi kernel: Using Buffer DMA mode
Sep 18 11:50:17 DietPi kernel: Periodic Transfer Interrupt Enhancement - disabled
Sep 18 11:50:17 DietPi kernel: Multiprocessor Interrupt Enhancement - disabled
Sep 18 11:50:17 DietPi kernel: OTG VER PARAM: 0, OTG VER FLAG: 0
Sep 18 11:50:17 DietPi kernel: Dedicated Tx FIFOs mode
Sep 18 11:50:17 DietPi kernel: WARN::dwc_otg_hcd_init:1074: FIQ DMA bounce buffers: virt = b7504000 dma = 0xf7504000 len=9024
Sep 18 11:50:17 DietPi kernel: FIQ FSM acceleration enabled for :
Sep 18 11:50:17 DietPi kernel: dwc_otg: Microframe scheduler enabled
Sep 18 11:50:17 DietPi kernel: WARN::hcd_init_fiq:457: FIQ on core 1
Sep 18 11:50:17 DietPi kernel: WARN::hcd_init_fiq:458: FIQ ASM at 807c8db0 length 36
Sep 18 11:50:17 DietPi kernel: WARN::hcd_init_fiq:497: MPHI regs_base at bb810000
Sep 18 11:50:17 DietPi kernel: dwc_otg 3f980000.usb: DWC OTG Controller
Sep 18 11:50:17 DietPi kernel: dwc_otg 3f980000.usb: new USB bus registered, assigned bus number 1
Sep 18 11:50:17 DietPi kernel: dwc_otg 3f980000.usb: irq 89, io mem 0x00000000
Sep 18 11:50:17 DietPi kernel: Init: Port Power? op_state=1
Sep 18 11:50:17 DietPi kernel: Init: Power Port (0)
Sep 18 11:50:17 DietPi kernel: usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.10
Sep 18 11:50:17 DietPi kernel: usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
Sep 18 11:50:17 DietPi kernel: usb usb1: Product: DWC OTG Controller
Sep 18 11:50:17 DietPi kernel: usb usb1: Manufacturer: Linux 5.10.60-v7+ dwc_otg_hcd
Sep 18 11:50:17 DietPi kernel: usb usb1: SerialNumber: 3f980000.usb
Sep 18 11:50:17 DietPi kernel: hub 1-0:1.0: USB hub found
Sep 18 11:50:17 DietPi kernel: hub 1-0:1.0: 1 port detected
Sep 18 11:50:17 DietPi kernel: dwc_otg: FIQ enabled
Sep 18 11:50:17 DietPi kernel: dwc_otg: NAK holdoff enabled
Sep 18 11:50:17 DietPi kernel: dwc_otg: FIQ split-transaction FSM enabled
Sep 18 11:50:17 DietPi kernel: Module dwc_common_port init
Sep 18 11:50:17 DietPi kernel: usbcore: registered new interface driver usb-storage
Sep 18 11:50:17 DietPi kernel: mousedev: PS/2 mouse device common for all mice
Sep 18 11:50:17 DietPi kernel: bcm2835-wdt bcm2835-wdt: Broadcom BCM2835 watchdog timer
Sep 18 11:50:17 DietPi kernel: sdhci: Secure Digital Host Controller Interface driver
Sep 18 11:50:17 DietPi kernel: sdhci: Copyright(c) Pierre Ossman
Sep 18 11:50:17 DietPi kernel: mmc-bcm2835 3f300000.mmcnr: could not get clk, deferring probe
Sep 18 11:50:17 DietPi kernel: sdhost-bcm2835 3f202000.mmc: could not get clk, deferring probe
Sep 18 11:50:17 DietPi kernel: sdhci-pltfm: SDHCI platform and OF driver helper
Sep 18 11:50:17 DietPi kernel: ledtrig-cpu: registered to indicate activity on CPUs
Sep 18 11:50:17 DietPi kernel: hid: raw HID events driver (C) Jiri Kosina
Sep 18 11:50:17 DietPi kernel: usbcore: registered new interface driver usbhid
Sep 18 11:50:17 DietPi kernel: usbhid: USB HID core driver
Sep 18 11:50:17 DietPi kernel: Initializing XFRM netlink socket
Sep 18 11:50:17 DietPi kernel: NET: Registered protocol family 17
Sep 18 11:50:17 DietPi kernel: Key type dns_resolver registered
Sep 18 11:50:17 DietPi kernel: Registering SWP/SWPB emulation handler
Sep 18 11:50:17 DietPi kernel: Indeed it is in host mode hprt0 = 00021501
Sep 18 11:50:17 DietPi kernel: registered taskstats version 1
Sep 18 11:50:17 DietPi kernel: Loading compiled-in X.509 certificates
Sep 18 11:50:17 DietPi kernel: Key type ._fscrypt registered
Sep 18 11:50:17 DietPi kernel: Key type .fscrypt registered
Sep 18 11:50:17 DietPi kernel: Key type fscrypt-provisioning registered
Sep 18 11:50:17 DietPi kernel: uart-pl011 3f201000.serial: cts_event_workaround enabled
Sep 18 11:50:17 DietPi kernel: 3f201000.serial: ttyAMA0 at MMIO 0x3f201000 (irq = 114, base_baud = 0) is a PL011 rev2
Sep 18 11:50:17 DietPi kernel: bcm2835-power bcm2835-power: Broadcom BCM2835 power domains driver
Sep 18 11:50:17 DietPi kernel: mmc-bcm2835 3f300000.mmcnr: mmc_debug:0 mmc_debug2:0
Sep 18 11:50:17 DietPi kernel: mmc-bcm2835 3f300000.mmcnr: DMA channel allocated
Sep 18 11:50:17 DietPi kernel: sdhost: log_buf @ (ptrval) (f7507000)
Sep 18 11:50:17 DietPi kernel: mmc1: queuing unknown CIS tuple 0x80 (2 bytes)
Sep 18 11:50:17 DietPi kernel: usb 1-1: new high-speed USB device number 2 using dwc_otg
Sep 18 11:50:17 DietPi kernel: mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
Sep 18 11:50:17 DietPi kernel: Indeed it is in host mode hprt0 = 00001101
Sep 18 11:50:17 DietPi kernel: mmc0: sdhost-bcm2835 loaded - DMA enabled (>1)
Sep 18 11:50:17 DietPi kernel: of_cfs_init
Sep 18 11:50:17 DietPi kernel: of_cfs_init: OK
Sep 18 11:50:17 DietPi kernel: Waiting for root device PARTUUID=cb7b86f7-02...
Sep 18 11:50:17 DietPi kernel: mmc1: queuing unknown CIS tuple 0x80 (7 bytes)
Sep 18 11:50:17 DietPi kernel: mmc0: host does not support reading read-only switch, assuming write-enable
Sep 18 11:50:17 DietPi kernel: mmc0: new high speed SDHC card at address aaaa
Sep 18 11:50:17 DietPi kernel: mmcblk0: mmc0:aaaa SL16G 14.8 GiB
Sep 18 11:50:17 DietPi kernel:  mmcblk0: p1 p2
Sep 18 11:50:17 DietPi kernel: mmc1: new high speed SDIO card at address 0001
Sep 18 11:50:17 DietPi kernel: EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
Sep 18 11:50:17 DietPi kernel: VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
Sep 18 11:50:17 DietPi kernel: devtmpfs: mounted
Sep 18 11:50:17 DietPi kernel: usb 1-1: New USB device found, idVendor=0424, idProduct=9514, bcdDevice= 2.00
Sep 18 11:50:17 DietPi kernel: Freeing unused kernel memory: 1024K
Sep 18 11:50:17 DietPi kernel: usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
Sep 18 11:50:17 DietPi kernel: Run /sbin/init as init process
Sep 18 11:50:17 DietPi kernel: hub 1-1:1.0: USB hub found
Sep 18 11:50:17 DietPi kernel:   with arguments:
Sep 18 11:50:17 DietPi kernel:     /sbin/init
Sep 18 11:50:17 DietPi kernel:   with environment:
Sep 18 11:50:17 DietPi kernel:     HOME=/
Sep 18 11:50:17 DietPi kernel:     TERM=linux
Sep 18 11:50:17 DietPi kernel: hub 1-1:1.0: 5 ports detected
Sep 18 11:50:17 DietPi kernel: usb 1-1.1: new high-speed USB device number 3 using dwc_otg
Sep 18 11:50:17 DietPi kernel: usb 1-1.1: New USB device found, idVendor=0424, idProduct=ec00, bcdDevice= 2.00
Sep 18 11:50:17 DietPi kernel: usb 1-1.1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
Sep 18 11:50:17 DietPi kernel: smsc95xx v2.0.0
Sep 18 11:50:17 DietPi systemd[1]: System time before build time, advancing clock.
Sep 18 11:50:17 DietPi kernel: libphy: smsc95xx-mdiobus: probed
Sep 18 11:50:17 DietPi kernel: smsc95xx 1-1.1:1.0 eth0: register 'smsc95xx' at usb-3f980000.usb-1.1, smsc95xx USB 2.0 Ethernet, b8:27:eb:cd:0e:c9
Sep 18 11:50:17 DietPi kernel: NET: Registered protocol family 10
Sep 18 11:50:17 DietPi kernel: Segment Routing with IPv6
Sep 18 11:50:17 DietPi kernel: usb 1-1.4: new full-speed USB device number 4 using dwc_otg
Sep 18 11:50:17 DietPi systemd[1]: systemd 247.3-6+rpi1 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +ZSTD +SECCOMP +BLKID +ELFUTILS +KMOD +IDN2 -IDN +PCRE2 default-hierarchy=unified)
Sep 18 11:50:17 DietPi systemd[1]: Detected architecture arm.
Sep 18 11:50:17 DietPi systemd[1]: Set hostname to <DietPi>.
Sep 18 11:50:17 DietPi kernel: usb 1-1.4: New USB device found, idVendor=046d, idProduct=c52b, bcdDevice=12.01
Sep 18 11:50:17 DietPi kernel: usb 1-1.4: New USB device strings: Mfr=1, Product=2, SerialNumber=0
Sep 18 11:50:17 DietPi kernel: usb 1-1.4: Product: USB Receiver
Sep 18 11:50:17 DietPi kernel: usb 1-1.4: Manufacturer: Logitech
Sep 18 11:50:17 DietPi kernel: input: Logitech USB Receiver as /devices/platform/soc/3f980000.usb/usb1/1-1/1-1.4/1-1.4:1.0/0003:046D:C52B.0001/input/input0
Sep 18 11:50:17 DietPi kernel: hid-generic 0003:046D:C52B.0001: input,hidraw0: USB HID v1.11 Keyboard [Logitech USB Receiver] on usb-3f980000.usb-1.4/input0
Sep 18 11:50:17 DietPi kernel: input: Logitech USB Receiver Mouse as /devices/platform/soc/3f980000.usb/usb1/1-1/1-1.4/1-1.4:1.1/0003:046D:C52B.0002/input/input1
Sep 18 11:50:17 DietPi kernel: input: Logitech USB Receiver Consumer Control as /devices/platform/soc/3f980000.usb/usb1/1-1/1-1.4/1-1.4:1.1/0003:046D:C52B.0002/input/input2
Sep 18 11:50:17 DietPi kernel: input: Logitech USB Receiver System Control as /devices/platform/soc/3f980000.usb/usb1/1-1/1-1.4/1-1.4:1.1/0003:046D:C52B.0002/input/input3
Sep 18 11:50:17 DietPi kernel: hid-generic 0003:046D:C52B.0002: input,hiddev96,hidraw1: USB HID v1.11 Mouse [Logitech USB Receiver] on usb-3f980000.usb-1.4/input1
Sep 18 11:50:17 DietPi kernel: hid-generic 0003:046D:C52B.0003: hiddev97,hidraw2: USB HID v1.11 Device [Logitech USB Receiver] on usb-3f980000.usb-1.4/input2
Sep 18 11:50:17 DietPi systemd[1]: Queued start job for default target Graphical Interface.
Sep 18 11:50:17 DietPi kernel: random: systemd: uninitialized urandom read (16 bytes read)
Sep 18 11:50:17 DietPi systemd[1]: Created slice system-getty.slice.
Sep 18 11:50:17 DietPi systemd[1]: Created slice system-modprobe.slice.
Sep 18 11:50:17 DietPi systemd[1]: Created slice system-openvpn.slice.
Sep 18 11:50:17 DietPi systemd[1]: Created slice system-systemd\x2dfsck.slice.
Sep 18 11:50:17 DietPi systemd[1]: Created slice system-wg\x2dquick.slice.
Sep 18 11:50:17 DietPi systemd[1]: Created slice User and Session Slice.
Sep 18 11:50:17 DietPi systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
Sep 18 11:50:17 DietPi systemd[1]: Started Forward Password Requests to Wall Directory Watch.
Sep 18 11:50:17 DietPi systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
Sep 18 11:50:17 DietPi systemd[1]: Reached target Local Encrypted Volumes.
Sep 18 11:50:17 DietPi systemd[1]: Reached target Host and Network Name Lookups.
Sep 18 11:50:17 DietPi systemd[1]: Reached target Paths.
Sep 18 11:50:17 DietPi systemd[1]: Reached target Remote File Systems.
Sep 18 11:50:17 DietPi systemd[1]: Reached target Slices.
Sep 18 11:50:17 DietPi systemd[1]: Listening on Syslog Socket.
Sep 18 11:50:17 DietPi systemd[1]: Listening on fsck to fsckd communication Socket.
Sep 18 11:50:17 DietPi systemd[1]: Listening on initctl Compatibility Named Pipe.
Sep 18 11:50:17 DietPi systemd[1]: Listening on Journal Audit Socket.
Sep 18 11:50:17 DietPi systemd[1]: Listening on Journal Socket (/dev/log).
Sep 18 11:50:17 DietPi systemd[1]: Listening on Journal Socket.
Sep 18 11:50:17 DietPi systemd[1]: Listening on udev Control Socket.
Sep 18 11:50:17 DietPi systemd[1]: Listening on udev Kernel Socket.
Sep 18 11:50:17 DietPi systemd[1]: Condition check resulted in Huge Pages File System being skipped.
Sep 18 11:50:17 DietPi systemd[1]: Mounting POSIX Message Queue File System...
Sep 18 11:50:17 DietPi systemd[1]: Mounting Kernel Debug File System...
Sep 18 11:50:17 DietPi systemd[1]: Mounting Kernel Trace File System...
Sep 18 11:50:17 DietPi systemd[1]: Starting Restore / save the current clock...
Sep 18 11:50:17 DietPi systemd[1]: Starting Set the console keyboard layout...
Sep 18 11:50:17 DietPi systemd[1]: Starting Create list of static device nodes for the current kernel...
Sep 18 11:50:17 DietPi systemd[1]: Starting Load Kernel Module configfs...
Sep 18 11:50:17 DietPi systemd[1]: Starting Load Kernel Module drm...
Sep 18 11:50:17 DietPi systemd[1]: Starting Load Kernel Module fuse...
Sep 18 11:50:17 DietPi systemd[1]: Started Nameserver information manager.
Sep 18 11:50:17 DietPi systemd[1]: Condition check resulted in Set Up Additional Binary Formats being skipped.
Sep 18 11:50:17 DietPi systemd[1]: Starting File System Check on Root Device...
Sep 18 11:50:17 DietPi kernel: fuse: init (API version 7.32)
Sep 18 11:50:17 DietPi systemd[1]: Starting Journal Service...
Sep 18 11:50:17 DietPi systemd[1]: Starting Load Kernel Modules...
Sep 18 11:50:17 DietPi systemd[1]: Starting Coldplug All udev Devices...
Sep 18 11:50:17 DietPi systemd[1]: Mounted POSIX Message Queue File System.
Sep 18 11:50:17 DietPi systemd[1]: Mounted Kernel Debug File System.
Sep 18 11:50:17 DietPi systemd[1]: Mounted Kernel Trace File System.
Sep 18 11:50:17 DietPi systemd[1]: Finished Restore / save the current clock.
Sep 18 11:50:17 DietPi systemd[1]: Finished Create list of static device nodes for the current kernel.
Sep 18 11:50:17 DietPi systemd[1]: modprobe@configfs.service: Succeeded.
Sep 18 11:50:17 DietPi systemd[1]: Finished Load Kernel Module configfs.
Sep 18 11:50:17 DietPi systemd[1]: modprobe@drm.service: Succeeded.
Sep 18 11:50:17 DietPi systemd[1]: Finished Load Kernel Module drm.
Sep 18 11:50:17 DietPi systemd[1]: modprobe@fuse.service: Succeeded.
Sep 18 11:50:17 DietPi systemd[1]: Finished Load Kernel Module fuse.
Sep 18 11:50:17 DietPi systemd[1]: Finished Load Kernel Modules.
Sep 18 11:50:17 DietPi systemd[1]: Started Journal Service.
Sep 18 11:50:17 DietPi kernel: EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
Sep 18 11:50:18 DietPi kernel: Adding 1098748k swap on /var/swap.  Priority:-2 extents:8 across:1246204k SSFS
Sep 18 11:50:18 DietPi kernel: vc_sm_cma: module is from the staging directory, the quality is unknown, you have been warned.
Sep 18 11:50:18 DietPi kernel: bcm2835_vc_sm_cma_probe: Videocore shared memory driver
Sep 18 11:50:18 DietPi kernel: [vc_sm_connected_init]: start
Sep 18 11:50:18 DietPi kernel: [vc_sm_connected_init]: installed successfully
Sep 18 11:50:18 DietPi kernel: smsc95xx 1-1.1:1.0 enxb827ebcd0ec9: renamed from eth0
Sep 18 11:50:19 DietPi kernel: cfg80211: Loading compiled-in X.509 certificates for regulatory database
Sep 18 11:50:19 DietPi kernel: cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
Sep 18 11:50:19 DietPi kernel: cfg80211: loaded regulatory.db is malformed or signature is missing/invalid
Sep 18 11:50:19 DietPi kernel: brcmfmac: F1 signature read @0x18000000=0x1541a9a6
Sep 18 11:50:19 DietPi kernel: brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43430-sdio for chip BCM43430/1
Sep 18 11:50:19 DietPi kernel: usbcore: registered new interface driver brcmfmac
Sep 18 11:50:19 DietPi kernel: brcmfmac: brcmf_c_process_clm_blob: no clm_blob available (err=-2), device may have limited channels available
Sep 18 11:50:19 DietPi kernel: brcmfmac: brcmf_c_preinit_dcmds: Firmware: BCM43430/1 wl0: Oct 22 2019 01:59:28 version 7.45.98.94 (r723000 CY) FWID 01-3b33decd
Sep 18 11:50:19 DietPi kernel: logitech-djreceiver 0003:046D:C52B.0003: hiddev96,hidraw0: USB HID v1.11 Device [Logitech USB Receiver] on usb-3f980000.usb-1.4/input2
Sep 18 11:50:19 DietPi kernel: random: crng init done
Sep 18 11:50:19 DietPi kernel: random: 7 urandom warning(s) missed due to ratelimiting
Sep 18 11:50:19 DietPi kernel: input: Logitech Wireless Device PID:400e Keyboard as /devices/platform/soc/3f980000.usb/usb1/1-1/1-1.4/1-1.4:1.2/0003:046D:C52B.0003/0003:046D:400E.0004/input/input5
Sep 18 11:50:19 DietPi kernel: input: Logitech Wireless Device PID:400e Mouse as /devices/platform/soc/3f980000.usb/usb1/1-1/1-1.4/1-1.4:1.2/0003:046D:C52B.0003/0003:046D:400E.0004/input/input6
Sep 18 11:50:19 DietPi kernel: input: Logitech Wireless Device PID:400e Consumer Control as /devices/platform/soc/3f980000.usb/usb1/1-1/1-1.4/1-1.4:1.2/0003:046D:C52B.0003/0003:046D:400E.0004/input/input7
Sep 18 11:50:19 DietPi kernel: hid-generic 0003:046D:400E.0004: input,hidraw1: USB HID v1.11 Keyboard [Logitech Wireless Device PID:400e] on usb-3f980000.usb-1.4/input2:1
Sep 18 11:50:20 DietPi kernel: input: Logitech K400 as /devices/platform/soc/3f980000.usb/usb1/1-1/1-1.4/1-1.4:1.2/0003:046D:C52B.0003/0003:046D:400E.0004/input/input11
Sep 18 11:50:20 DietPi kernel: logitech-hidpp-device 0003:046D:400E.0004: input,hidraw1: USB HID v1.11 Keyboard [Logitech K400] on usb-3f980000.usb-1.4/input2:1
Sep 18 11:50:22 DietPi kernel: brcmfmac: brcmf_cfg80211_set_power_mgmt: power save enabled
Sep 18 11:50:24 DietPi kernel: IPv6: ADDRCONF(NETDEV_CHANGE): wlan0: link becomes ready
Sep 18 18:04:32 DietPi kernel: FS-Cache: Netfs 'cifs' registered for caching
Sep 18 18:04:32 DietPi kernel: Key type cifs.spnego registered
Sep 18 18:04:32 DietPi kernel: Key type cifs.idmap registered
Sep 18 18:04:32 DietPi kernel: CIFS: Attempting to mount //192.168.115.5/FB-7590-Router/USBDISK3-0-01/Musik
Sep 18 18:04:32 DietPi kernel: CIFS: Attempting to mount //192.168.115.130/FRITZ.NAS/HDD_250_GB/Musik
Sep 18 18:04:32 DietPi kernel: CIFS: Attempting to mount //192.168.115.130/FRITZ.NAS/NAS_7490/Musik
Sep 18 18:04:32 DietPi kernel: CIFS: Attempting to mount //192.168.115.111/usbshare2/Musik
Sep 18 18:04:32 DietPi kernel: FS-Cache: Duplicate cookie detected
Sep 18 18:04:32 DietPi kernel: FS-Cache: O-cookie c=b670f09e [p=28c4494d fl=222 nc=0 na=1]
Sep 18 18:04:32 DietPi kernel: FS-Cache: O-cookie d=6547549f n=18eaee3b
Sep 18 18:04:32 DietPi kernel: FS-Cache: O-key=[8] '020001bdc0a87382'
Sep 18 18:04:32 DietPi kernel: FS-Cache: N-cookie c=c5963b75 [p=28c4494d fl=2 nc=0 na=1]
Sep 18 18:04:32 DietPi kernel: FS-Cache: N-cookie d=6547549f n=4e2eb2e7
Sep 18 18:04:32 DietPi kernel: FS-Cache: N-key=[8] '020001bdc0a87382'
Sep 18 18:04:32 DietPi kernel: CIFS: Status code returned 0xc000006d STATUS_LOGON_FAILURE
Sep 18 18:04:32 DietPi kernel: CIFS: VFS: \\192.168.115.5 Send error in SessSetup = -13
Sep 18 18:04:32 DietPi kernel: CIFS: VFS: cifs_mount failed w/return code = -13
Sep 18 18:04:32 DietPi kernel: tun: Universal TUN/TAP device driver, 1.6
Sep 18 18:04:33 DietPi kernel: wireguard: WireGuard 1.0.0 loaded. See www.wireguard.com for information.
Sep 18 18:04:33 DietPi kernel: wireguard: Copyright (C) 2015-2019 Jason A. Donenfeld <Jason@zx2c4.com>. All Rights Reserved.
Sep 18 18:04:38 DietPi kernel: CIFS: VFS: Error connecting to socket. Aborting operation.
Sep 18 18:04:38 DietPi kernel: CIFS: VFS: cifs_mount failed w/return code = -113
Is the solution to my problem still being worked on or do I have to set up a new system? My wife has written out all the appointments from the Baikal calendar on paper and I would then have to enter them into the new system, which I would like to avoid if possible.
eth0 is still not available, WiFi (and Baikal) works.
The problem started with the upgrade to Bullseye, eth0 was not available after a reboot. Then dietpie-backup -1, eth0 remained unavailable.
I would have to decide in the next two weeks to delete the broken system and set up a new DietPi system. Then the possibility for further forensic investigations would disappear.
Please write me what to do, thank you very much.
Ah I think I know what’s going on: “Predictable” network interface names.
Please try the following:
grep 'net.ifnames=0' /boot/cmdline.txt || sed -i '/root=/s/$/ net.ifnames=0/' /boot/cmdline.txt
reboot
On new images this is done already but on older it may not be present yet and with Bullseye systemd started to ignore an older solution.
it works!
root@DietPi:~# ifup eth0
ifup: interface eth0 already configured
root@DietPi:~# ifconfig
eth0: flags=4163<UP,BROADCAST,RUNNING,MULTICAST>  mtu 1500
        inet 192.168.115.31  netmask 255.255.255.0  broadcast 192.168.115.255
        inet6 fe80::ba27:ebff:fecd:ec9  prefixlen 64  scopeid 0x20<link>
        inet6 fd00::ba27:ebff:fecd:ec9  prefixlen 64  scopeid 0x0<global>
        inet6 2001:16b8:552d:dc00:ba27:ebff:fecd:ec9  prefixlen 64  scopeid 0x0<global>
        ether b8:27:eb:cd:0e:c9  txqueuelen 1000  (Ethernet)
        RX packets 1501  bytes 106219 (103.7 KiB)
        RX errors 0  dropped 0  overruns 0  frame 0
        TX packets 134  bytes 18869 (18.4 KiB)
        TX errors 0  dropped 0 overruns 0  carrier 0  collisions 0
lo: flags=73<UP,LOOPBACK,RUNNING>  mtu 65536
        inet 127.0.0.1  netmask 255.0.0.0
        inet6 ::1  prefixlen 128  scopeid 0x10<host>
        loop  txqueuelen 1000  (Lokale Schleife)
        RX packets 352  bytes 30934 (30.2 KiB)
        TX packets 352  bytes 30934 (30.2 KiB)
tun0: flags=4305<UP,POINTOPOINT,RUNNING,NOARP,MULTICAST>  mtu 1500
        inet 10.8.0.1  netmask 255.255.255.0  destination 10.8.0.1
        inet6 fe80::d0a8:589e:5271:3258  prefixlen 64  scopeid 0x20<link>
        unspec 00-00-00-00-00-00-00-00-00-00-00-00-00-00-00-00  txqueuelen 500  (UNSPEC)
        RX packets 0  bytes 0 (0.0 B)
        TX packets 279  bytes 16656 (16.2 KiB)
wg0: flags=209<UP,POINTOPOINT,RUNNING,NOARP>  mtu 1420
        inet 10.9.0.1  netmask 255.255.255.0  destination 10.9.0.1
        unspec 00-00-00-00-00-00-00-00-00-00-00-00-00-00-00-00  txqueuelen 1000  (UNSPEC)
        TX packets 0  bytes 0 (0.0 B)
        TX errors 252  dropped 0 overruns 0  carrier 0  collisions 0
wlan0: flags=4163<UP,BROADCAST,RUNNING,MULTICAST>  mtu 1500
        inet 192.168.115.30  netmask 255.255.255.0  broadcast 192.168.115.255
        inet6 2001:16b8:552d:dc00:ba27:ebff:fe98:5b9c  prefixlen 64  scopeid 0x0<global>
        inet6 fe80::ba27:ebff:fe98:5b9c  prefixlen 64  scopeid 0x20<link>
        inet6 fd00::ba27:ebff:fe98:5b9c  prefixlen 64  scopeid 0x0<global>
        ether b8:27:eb:98:5b:9c  txqueuelen 1000  (Ethernet)
        RX packets 3017  bytes 833301 (813.7 KiB)
        RX errors 0  dropped 856  overruns 0  frame 0
        TX packets 14596  bytes 1979923 (1.8 MiB)
I would like to thank you very much for your support, also on behalf of my wife, because I could never have solved the problem on my own.
Many kind regards. :smiley:
Great. Another point that we need to add to the upgrade guide :slight_smile:.
Yes, that would be good.
If you wish, my postings can be shortened to a necessary minimum or parts of the thread that do not apply can be moved.
Thanks again for everything. :slight_smile:
ok I adjusted the post to increase readability.
And you should not use ifconfig anymore as it depreciated some years ago and has been replaced by ip suite. :wink:
for the once who still struggle with curl, pls try following
apt install --reinstall librtmp1
curl -I https://dietpi.com/
Thank you very much, I have executed the commands:
root@DietPi:~# apt install --reinstall librtmp1
Paketlisten werden gelesen… Fertig
Abhängigkeitsbaum wird aufgebaut… Fertig
Statusinformationen werden eingelesen… Fertig
0 aktualisiert, 0 neu installiert, 1 erneut installiert, 0 zu entfernen und 0 nicht aktualisiert.
Es müssen 54,2 kB an Archiven heruntergeladen werden.
Nach dieser Operation werden 0 B Plattenplatz zusätzlich benutzt.
Holen:1 http://raspbian.raspberrypi.org/raspbian bullseye/main armhf librtmp1 armhf 2.4+20151223.gitfa8646d.1-2+b2 [54,2 kB]
Es wurden 54,2 kB in 1 s geholt (88,6 kB/s).
(Lese Datenbank ... 99074 Dateien und Verzeichnisse sind derzeit installiert.)
Vorbereitung zum Entpacken von .../librtmp1_2.4+20151223.gitfa8646d.1-2+b2_armhf.deb ...
Entpacken von librtmp1:armhf (2.4+20151223.gitfa8646d.1-2+b2) über (2.4+20151223.gitfa8646d.1-2+b2) ...
librtmp1:armhf (2.4+20151223.gitfa8646d.1-2+b2) wird eingerichtet ...
Trigger für libc-bin (2.31-13+rpt2+rpi1) werden verarbeitet ...
root@DietPi:~# curl -I https://dietpi.com/
HTTP/2 200
date: Tue, 21 Sep 2021 15:11:26 GMT
content-type: text/html; charset=utf-8
x-content-type-options: nosniff
x-frame-options: SAMEORIGIN
x-xss-protection: 1; mode=block
x-robots-tag: all
x-download-options: noopen
x-permitted-cross-domain-policies: none
referrer-policy: no-referrer-when-downgrade
expect-ct: enforce, max-age=604800, report-uri="https://report-uri.cloudflare.com/cdn-cgi/beacon/expect-ct"
content-security-policy: upgrade-insecure-requests; frame-ancestors 'self'; form-action 'self'; base-uri https://dietpi.com/matomo/index.php https://dietpi.com/grafana/; default-src 'none'; object-src 'none'; style-src 'self' 'unsafe-inline' https://fonts.googleapis.com; font-src 'self' https://fonts.gstatic.com data:; img-src * data:; script-src 'self' 'unsafe-inline' 'unsafe-eval' https://unpkg.com https://google.com/recaptcha/ https://www.google.com/recaptcha/ https://www.gstatic.com/recaptcha/; frame-src 'self' https://www.youtube-nocookie.com https://google.com/recaptcha/ https://www.google.com/recaptcha/; manifest-src 'self'; connect-src 'self' https://api.github.com
permissions-policy: accelerometer=(), autoplay=(), camera=(), document-domain=(), encrypted-media=(), fullscreen=(self "https://www.youtube-nocookie.com"), geolocation=(), gyroscope=(), magnetometer=(), microphone=(), midi=(), payment=(), usb=(), screen-wake-lock=()
cache-control: public, max-age=86399
strict-transport-security: max-age=31536000; includeSubDomains; preload
last-modified: Sat, 18 Sep 2021 19:42:35 GMT
vary: Accept-Encoding
content-language: en
cf-cache-status: DYNAMIC
report-to: {"endpoints":[{"url":"https:\/\/a.nel.cloudflare.com\/report\/v3?s=CSTzNyFEqqZGlsY9DiXfFdTmt1bBPJ4T3XKAZiY3KW2DnQVAQTJ%2B9LDLmOdDvbs9F%2FETVk3zltuNPMKvRxx9So8BGPDkpr1rdiwWB6TpqKFIRq%2Bske0rTLbxfTYjOdNu8PX%2BObys4uM5"}],"group":"cf-nel","max_age":604800}
nel: {"success_fraction":0,"report_to":"cf-nel","max_age":604800}
server: cloudflare
cf-ray: 692439dd29942c2e-FRA
alt-svc: h3=":443"; ma=86400, h3-29=":443"; ma=86400, h3-28=":443"; ma=86400, h3-27=":443"; ma=86400
I will look into the IP package, thank you also for this advice and kind regards.
Great, so curl works now. As this was confirmed in another case as well, another point to add to the guide.
If I’m not mistaken, omavoss upgrade to Bullseye before and I guess curl was already working :smiley:
Yes, that’s right. Bullseye is on.
I apologise for causing confusion, I can only translate German to English via Deepl. So it is very difficult for me to express myself understandably.
Many greetings.
no problem. if needed write me a private message in German if needed. Something we understand :wink:
