I am trying to do as much as possible at install, so I want to use both of the automation scripts that dietpi provides
I am using this image: DietPi_ROCKPi4-ARMv8-Bookworm.img
I have a question regarding creating two folders with either the Automation_Custom_PreScript.sh or Automation_Custom_Script.sh
(both scripts have the same issue)
I have tried this:
mkdir /certs
mkdir /vpnprofiles
but the folders get created like this:
‘certs’$‘\r’
‘vpnprofiles’$‘\r’
after boot i can create them myself by doing sudo mkdir certs? but why cant i during install/automationscript?
You edited that file from a windows machine, did you? The \r is a windows/dos style symbol for the end of a line. You saved the file in windows style format and ran it on a unix machine.
In text editors like notepad++ you can convert the End Of Line Symbols between DOS and unix (and mac) to your requirements.
