apt auto completion not working
I found that a new refreshed install of DietPi does not come with apt auto completion working by default, to throublesoot this do this actions:
Run:
dietpi-config
Then go to:
4 - Advanced Options
APT-Cache
And then:
set the two options (APT cache and APT lists) to [On disk]
After that do:
sudo apt update
Now the command ‘sudo apt install ja[TAB][TAB]’ will work!
Maybe you can have a look. System default is APT cache and APT lists set to [On disk] according the system dialog. However APT cache is set to [Disabled] . Probably it was deactivated to reduce I/O and SD Card usage. But I’m not sure.
