Release Notes¶
June 2026 (version 10.5)¶
Overview¶
The June 14th, 2026 release of DietPi v10.5 comes with updates of the dietpi-config display options, especially for Raspberry Pis, moving from legacy to modern graphics and camera drivers and APIs.
Enhancements¶
- Raspberry Pi KMS/DRM is now enabled by default whenever a GUI application or desktop environment is installed via
dietpi-software, and it can be toggled with a new dedicateddietpi-configdisplay options entry. After several libraries for the legacy GPU firmware driver have been removed, using it has almost only downsides. Any application which made use of its features, like OpenMAX, DispmanX, and MMAL, cannot work anymore on any supported Raspberry Pi repository version. - Raspberry Pi The RPi Camera setting in
dietpi-confighas been updated to toggle the modern camera stack withlibcameraAPI, rather than the legacy one. The recent Linux 6.18 update removed support for the legacy MMAL camera stack, which also never worked with Camera Module 3. - DietPi-Tools | DietPi-Config The display menu has been reworked:
dietpi-displayis now the standard tool to configure display resolution/mode and rotation, the device-specific resolution menus for Raspberry Pi and Odroids have been removed, along with other legacy and dysfunctional options, namely RPi headless mode, HDMI rotation (now included indietpi-display), and PSU noise reduction. Like possible only on VMs before, it is now additionally possible on any system with GRUB bootloader, to configure the GRUB terminal and early boot console resolution, before the KMS video mode configured viadietpi-displayapplies. - DietPi-Software | RustDesk Client It has been enabled for the ARMv7 architecture after the latest release fixed package compatibility with Debian time64 transitioned packages.
Bug fixes¶
- NanoPi K2 Resolved an issue where setting a static Ethernet MAC address via
ethaddrvariable in/boot/dietpiEnv.txtdid not work, since U-Boot assigned a random MAC earlier, causing the variable to be immutable. However, the U-Boot methods to assign a static MAC via eFuse and OTP fallback reads both fail, hence the MAC address remains random, varying across boots, untilethaddris set in/boot/dietpiEnv.txt. If you want a static MAC address, we suggest to use the one assigned on any boot, to assure it is a valid one. On upgraded systems, U-Boot needs to be flashed, e.g. viadietpi-configAdvanced Options, for the change to take effect. Many thanks to @vatprcyq for reporting this issue: MichaIng/DietPi#8175 - DietPi-Tools | DietPi-Config Resolved an issue where the RTC mode option within Advanced Options was never shown, because the presence of
/dev/rtc*was checked incorrectly. Many thanks to @TheRaven500 for reporting this issue: https://github.com/MichaIng/DietPi/issues/7721#issuecomment-4649733270 - DietPi-Software | ownCloud Infinite Scale Resolved a v10.4 regression where on fresh installs, login via intended password failed, since the command argument was falsely added. Many thanks to @tonosama for reporting this issue, and @JappeHallunken for fixing it: https://dietpi.com/forum/t/25235
As always, many smaller code performance and stability improvements, visual and spelling fixes have been done, too much to list all of them here. Check out all code changes of this release on GitHub: MichaIng/DietPi!8173
